ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardLights( Port1,11,0,23,0 );
ReefAngel.StandardLights( Port2,12,0,16,0 );
ReefAngel.StandardLights( Port3,20,0,10,0 );
ReefAngel.Relay.DelayedOn( Port6,4 );
ReefAngel.Relay.DelayedOn( Port7,2 );
ReefAngel.SingleATO( true,Port8,240,0 );
ReefAngel.Portal( "cromanon" );
No control
Re: No control
Re: No control
just for second check, I reenter the ssid and pass in wifi , but no change.
Re: No control
Green blink on the wifi attachment means it is connected, so I don't think it's that.
It is sounding like head unit issue.
Is the controller switching relays on/off and just not responding to wifi or you don't hear it click relays at all?
Test it with your ATO float switch. Move it up and down. Does Port8 turn on/off?
Re: No control
yes, I move float sw and sound a click.
Re: No control
So, it seems the controller is operational and just the screen is malfunctioning, but the wifi should work too.
I'd check for water damage.
