Water level logging
lucho
Water level logging
Post by lucho »
Is there a way to chart the water level? I can chart PH and Temp, but not water level. My ATO relay is acting weird and would love to understand what is happening.
thanks
Re: Water level logging
Water level expansion or float switch?
lucho
Post by lucho »
Water level expansion. It should start at 38% and stop at 40%, but somehow it ran for 1 hour and now it is at 60%.
Smotz
Post by Smotz »
where is this chart ? how can I get to this from my portal?
It's not in the portal. It's stand alone. There's a list of parameters you can filter by floating around somewhere.
Smotz
Post by Smotz »
How come this doesn't work for me?
status/chart.aspx?id=Smotz&filter=WL
Cancel that! It's cause I got the multi-level water sensor.
I needed:
status/chart.aspx?id=Smotz&filter=WL1
A) Any way we can customize our Portals with these?
B) Can I see multiple charts on one page (WL2 & PWMA & PWMB ) ?
Smotz
Post by Smotz »
Thank you much, by the way..
You're welcome!
lucho
Post by lucho »
thanks, I will try this when I return home.
lucho
Post by lucho »
Is there a way to download the raw information from the charts? Not the chart, but the logged data underneath it.
thanks!
