Lighting Override???
PostPosted: Sun Aug 10, 2014 1:15 pm
by Sacohen
My lights, like most peoples, are LED controlled by the Dimming module for on/off and intensity.
How does the override function on the headunit and Andriod App work?
Do I need to have the lights plugged into a port on the relay or is just constant power from my battery backup fine?
Re: Lighting Override???
PostPosted: Mon Aug 11, 2014 1:49 pm
by Sacohen
Anyone???
PostPosted: Mon Aug 11, 2014 2:05 pm
The override simply overrides the output % to whatever you choose.
For example, override to 50% and it will stay at 50% no matter what your program is set to.
PostPosted: Mon Aug 11, 2014 2:10 pm
by Sacohen
And that is chosen on the RA Unit under Lighting, correct?
I believe I saw a PWM setting in there when I looked yesterday.
PostPosted: Mon Aug 11, 2014 2:18 pm
I dont follow the question...i think maybe your referring to the lights on ports?
No, that is set using the android app or U-app or wifi command
PostPosted: Mon Aug 11, 2014 2:49 pm
by Sacohen
OK. Then what is that section on the RA menu for?
PostPosted: Mon Aug 11, 2014 2:57 pm
Well, that also does do override too, but you must assign something to LightsOnPort variable and override the relay you set to the LightsOnPort port. So, yes... It does require a relay, but could also be a virtual relay though.
The override from the app goes straight to the channels and doesn't require a relay.
PostPosted: Mon Aug 11, 2014 3:09 pm
by Sacohen
Ok. Thanks.
