Dimmer expansion and Coralux 5up LDD board setup
Posted: Tue Aug 12, 2014 12:50 pm
by juszczyk
hi, do I use one or all three grounds on the dimmer expansion and does it go to one of the grounds on the Corolux 5up board or to one of the -v on PS?
can you also explain why there are three grounds on the dimmer, thanks
trying to get all my wires going to corrects locations and there are a lot of wires.
Re: Dimmer expansion and Coralux 5up LDD board setup
Posted: Tue Aug 12, 2014 12:52 pm
Just to make it easier. You should be able to use any ground. I would use the dimming module one.
Posted: Tue Aug 12, 2014 1:10 pm
by juszczyk
thanks Inevo, and does this ground go to the LDD boards ground or to the -v on PS, cheers
Posted: Tue Aug 12, 2014 1:13 pm
No sure how the board you mentioned is layout, but the ground from the power supply definitely needs to share the same ground of the dimming module.
Posted: Tue Aug 12, 2014 2:54 pm
by juszczyk
ok, moved the ground from dimmer to -v on ps. still no success. If someone can look at my wiring to make sure everything looks ok would be great. I think my jumpers are correct for 5v pwm. Maybe I should try taking that lone jumper off to change from 40 to 41?
If everything looks ok, then I guess next step is looking at programing. Worst thing in world is thinking everything is good to go and once power is turned on, nothing happens.
Posted: Tue Aug 12, 2014 3:08 pm
It's the opposite.
You cannot use the jumper.
Jumper On = 0x41 - It will be used by the 16ch custom dimming expansion module
Jumper Off = 0x40 - To be used on the current 6ch dimming expansion module
Posted: Thu Oct 30, 2014 9:13 am
by HodagReef
juszczyk,
Did you get your set-up to work? I'm thinking of doing something similar.
