if (hour()<8 || hour()>20) ReefAngel.RF.SetMode( ReefCrest,20,10 );
//Start of PWM Expansion Code Header
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
0,0,0,0,0,0};
//End of PWM Expansion Code Header
ReefAngel.WaterChangePorts = Port1Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,760,775 );
ReefAngel.StandardLights( Port2,20,0,4,0 );
ReefAngel.StandardLights( Port3,10,0,19,0 );
ReefAngel.StandardLights( Port4,9,0,20,0 );
ReefAngel.StandardLights( Port5,10,0,19,0 );
ReefAngel.StandardLights( Port6,9,0,20,0 );
// ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,0,100,0) );
// ReefAngel.PWM.SetChannel( 1, PWMParabola(10,0,19,0,0,100,0) );
// ReefAngel.PWM.SetChannel( 2, PWMParabola(10,0,19,0,0,100,0) );
ReefAngel.RF.SetMode( NutrientTransport,85,10 );
PWMChannel[LEDPWM0]=PWMParabola(9,0,20,0,0,100,PWMChannel[LEDPWM0]);
PWMChannel[LEDPWM1]=PWMParabola(10,0,19,0,0,100,PWMChannel[LEDPWM1]);
PWMChannel[LEDPWM2]=PWMParabola(10,0,19,0,0,100,PWMChannel[LEDPWM2]);
CheckCloud();
ReefAngel.PWM.SetChannel( LEDPWM0, int(2.55*PWMChannel[LEDPWM0]));
ReefAngel.PWM.SetChannel( LEDPWM1, int(2.55*PWMChannel[LEDPWM1]));
ReefAngel.PWM.SetChannel( LEDPWM2, int(2.55*PWMChannel[LEDPWM2]));
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Actinic_Channels B000001
#define Daylight_Channels B000110
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
for (int a=0;a<6;a++)
PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
for (int b=0;b<6;b++)
else lightningstatus=0;
if (lightningstatus) PWMChannel[b]=100;
else PWMChannel[b]=0;
//delay(10);
PWMChannel[b]=20;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
