ok, got it to download on my old pc but i now cant locate the Wifi Utility application? manual says it was loaded with the installer? where would i find that?
thanks so much Colin
just received my new reef angel
Re: just received my new reef angel
i have the wifi attachment plugged into a usb on my windows computer and ready to proceed.
Is there an icon on the desktop?
C:\Program Files (x86)\Reef Angel Controller\Wifi_Utility.exe
thank you very much Colin, its up and running.
now of course this will lead to other questions , but I'll save those for another day:)
cheers
cheers
Woo hoo!
Now, you need to set a fixed IP in your router for the WiFi adapter address. Forward port 2000 to this address. It'll save headaches in the future.
how do i do that? didnt see that in the manual?
thanks
thanks
Check your router manual. If your router ever looses power, the IP address it assigns to the WiFi adapter may change. Setting a static IP in your router prevents this. On my Cisco/Linksys router it's under "DHCP Reservation".
Port forwarding makes sure everything that's supposed to get to the WiFi adapter does. On my router it's under "Applications and Gaming" and "Single Port Forwarding".
