wavemaker random option
Re: wavemaker random option
Oh, and you're welcome. I've had 5 days off and I've had a lot of computer time. :D
Reefology
Post by Reefology »
basically yes
Reefology
Post by Reefology »
lol, I've had a lot of computer time as well over the holidays...trying to squeeze a little more in before i head out to work :D
Nothinng in your code so long as port forwarding is set right should give you an error from the portal. If you had all hard coded you could still use the portal to preset all the memory locations. Can you screenshot the error?
Reefology
Post by Reefology »
now i got this error msg trying to upload the screenshot.
Screenshot from 2015-01-05 17:19:22.png is an invalid filename.
Reefology
Post by Reefology »
did this work?
Ok so your port forwarding is good but I think your confused about wavemaker and dcpump. Not sure why you got that error, but Wavemaker means you are using relay port 5 and 6 with simple on/off powerheads. The DCPump is used to control Jaebo style controllable pumps. So which are you using? If you have the jaebo pumps they don't have to use up a port on your relay bar and you don't want to be doing the wavemaker functions with them.
And now that your banner is working i can see you have one jaebo and one koralia.
Could you start a thread and post your current code that your using? We can keep all the questions related to your setup in one place :)
Reefology
Post by Reefology »
Absolutely...will do.
