Error:
Watchdog Timer
Version Menu
Dimming Signal
DC Pump Control (Jebao/Tunze)
2014 Main Screen
Extra Font - Medium Size (8x8 pixels)
Standard Menu
Globals/Globals.cpp.o: In function `ElseMode(unsigned char, unsigned char, unsigned char)':
/Users/Matt/Documents/Arduino/libraries/Globals/Globals.cpp:881: multiple definition of `ElseMode(unsigned char, unsigned char, unsigned char)'
sketch_jun13a_multimode_pump_v9.cpp.o:sketch_jun13a_multimode_pump_v9.cpp:124: first defined here
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld: Disabling relaxation: it will not work with multiple definitions
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.StandardATO( Port1,7200 );
ReefAngel.StandardLights( Port2,22,0,10,0 );
ReefAngel.StandardLights( Port3,11,0,22,15 );
ReefAngel.StandardLights( Port4,12,0,22,0 );
ReefAngel.StandardHeater( Port7,770,780 );
if (hour()>=0 && hour()<6)
ReefAngel.PWM.SetDaylight( ElseMode(30,10,true) ); // Else on sync mode
ReefAngel.PWM.SetActinic( ElseMode(30,10,false) ); // Else on sync mode
else if (hour()>=6 && hour()<10)
ReefAngel.PWM.SetDaylight( ElseMode(40,20,true) ); // Else on sync mode
ReefAngel.PWM.SetActinic( ElseMode(40,20,false) ); // Else on sync mode
else if (hour()>=10 && hour()<13)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
else if (hour()>=13 && hour()<22)
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,90,800,true) ); // Short pulse at 80% with 800ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,90,800,true) ); // Short pulse at 80% with 800ms pulse on sync mode
else if (hour()>=22 && hour()<=24)
ReefAngel.PWM.SetDaylight( ReefCrestMode(40,20,true) ); // reefcrest at 40% hours 22-24 on sync
ReefAngel.PWM.SetActinic( ReefCrestMode(40,20,true) ); //
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
