Reefology's code
PostPosted: Mon Jan 05, 2015 4:23 pm
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.DDNS( "" );
    ReefAngel.DosingPumpRepeat1( Port1 );
    ReefAngel.MoonLights( Port2 );
    ReefAngel.ActinicLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.WavemakerRandom( Port5,119,1200 );
    ReefAngel.WavemakerRandom( Port6,99,1000 );
    ReefAngel.Portal( "" );
    ReefAngel.DDNS( "" ); // Your DDNS is
PostPosted: Mon Jan 05, 2015 4:25 pm
so should i take the jebao port offline? well it isn't working anyway :D
PostPosted: Mon Jan 05, 2015 4:53 pm
Just set it to always on, or plug it into a power strip. Let the stock Jebao controller handle the pump, unless you want to use a Jebao cable to control it with the RA.
You also need to remove this line:
ReefAngel.DDNS( "Reefology" ); // Your DDNS is Reefology-tank.myreefangel.com
You already have a DDNS declaration in setup(). That's probably why you're having issues with your phone app.
PostPosted: Mon Jan 05, 2015 4:58 pm
great Colin, will do. But you might want to note that i didnt manually add it, was done by the wizard.
I also wanted to add password authentication but havent' figured out how, can you help me with that? I'm aware i won't be able to use the iphone app until its supported.
thanks
PostPosted: Mon Jan 05, 2015 5:48 pm
Must have been an evil Wizard. Voldemort is my guess. ;)
I don't use the password authentication. Maybe someone else can chime in. I do know you won't be able to use the iPhone app if you enable it.
PostPosted: Mon Jan 05, 2015 5:51 pm
Add this in setup
ReefAngel.Network.WifiAuthentication("username:password");
Change username and password for whatever you'd like it to be.
PostPosted: Mon Jan 05, 2015 6:14 pm
great thanks, i forgot Roberto had already given it to me just couldn't find it.
PostPosted: Thu Jan 08, 2015 10:53 am
Added this custom code that i copied from anothher user but not getting desired result. Can someone explain each section so i can learn the code and make adjustments going forward please?
FYI, i changed ''if (now()%SECS_PER_DAY==600'' from 0 to 600 hoping to change mode every 10 mins.
static int rmode;
    byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre };
    if (now()%SECS_PER_DAY==600 || changeMode==true) { // Change every 10 mins or if controller rebooted
    changeMode=false;
    static unsigned long feeding;
    if (now()-feeding<3600) {
    } else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
    // Night mode (go to 30%)
    ReefAngel.DCPump.Mode=Sine;
    ReefAngel.DCPump.Speed=30;
PostPosted: Thu Jan 08, 2015 11:00 am
What desired behavior are you trying to get and what behavior are you seeing instead..
PostPosted: Thu Jan 08, 2015 12:52 pm
thanks for the quick response. I have a single WP40 and would like to have alternate wave modes that change throughout each day, I'd like a calm mode at night running at 30% or less if possible (but not sure it is), I'd like to override via internal memory if possible and then have it revert back to random after a set time (but not a must have).
I like the way it kicks into night mode and feed mode but it doesnt alternate wave patterns listed in the code its stuck in else mode.
Next
Return to Ask anything here
