Reefology's code
Posted: Mon Jan 05, 2015 4:23 pm
Current code
Original Post
void SeasonalTemps ()
static int heatArray[][2] = { {778,784},// default in case of error in month=0 (May)
{762,768},//January (winter)
{766,772},//February (winter)
{770,776},//March (early spring)
{774,780},//April (spring)
{778,784},//May (spring)
{782,788},//June (early summer)
{786,792},//July (summer)
{782,788},//August (summer)
{778,784},//September (early fall)
{772,780},//October (fall)
{770,776},//November (fall)
{766,772} };//December (early winter)
ReefAngel.StandardHeater( Port1,heatArray[month()][0],heatArray[month()][1]);
}//end seasonalTemps
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit;
//Feeding Timer
ReefAngel.Timer[FEEDING_TIMER].SetInterval(2100);
SeasonalTemps();
ReefAngel.ActinicLights( Port2 ); // Royal blue led strip
ReefAngel.DayLights( Port4 ); // T5's
ReefAngel.StandardFan( Port6 );
// koralia 1150
// if (hour()>=23 || hour()<11) ReefAngel.Relay.Off( Port5 );
// else ReefAngel.WavemakerRandom( Port5, 120, 1800 );
//ATO
//if ((hour()>=20 || hour()<=8) && (ReefAngel.Params.PH < 830))
// ReefAngel.SingleATO(false,Port5,180,0); // Sump switch. Kalk schedule 8pm - 8am if pH < 8.3 If ATO/Kalk runs for 180 seconds, shut off and send alert.
// else
// ReefAngel.SingleATO(false,Port8,180,0); // Sump switch. If ATO/RoDi runs for 180 seconds, shut off and send alert.
//skimmer off when collection container is full
if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port3);
else ReefAngel.StandardLights( Port3, 17,0,9,0); //skimmer off 9am-5pm
//light mover
//if (hour()>=9 && hour()<=21) ReefAngel.DosingPumpRepeat( Port6,0,90,2 ); // from 9am - 9pm, moves 2 seconds every 90 minutes with 0 minutes offset
//else ReefAngel.Relay.Off( Port6);
//kalk dosing
if ((hour()>13 && hour()<20) || (ReefAngel.Params.PH > 845))
ReefAngel.Relay.Off( Port7); // Kalk off 1pm - 8pm & if pH is > 8.45
ReefAngel.PHControl( Port7 );
//carbon dosing
if (hour()>=6 && hour()<23) ReefAngel.DosingPumpRepeat1( Port8 );
else ReefAngel.Relay.Off( Port8);
ReefAngel.Portal( "reefology" );
Original Post
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.DDNS( "" );
ReefAngel.DosingPumpRepeat1( Port1 );
ReefAngel.MoonLights( Port2 );
ReefAngel.ActinicLights( Port3 );
ReefAngel.WavemakerRandom( Port5,119,1200 );
ReefAngel.WavemakerRandom( Port6,99,1000 );
ReefAngel.Portal( "" );
ReefAngel.DDNS( "" ); // Your DDNS is
