Reefology's code
Re: Reefology's code
I think it's this line here.
if (now()%SECS_PER_DAY==600 || changeMode==true) { // Change every 10 mins or if controller rebooted
This tells it to change modes every 24 hours and 10 minutes.
Try changing it to this.
if (now()%600==0 || changeMode==true) {
Edit: Forgot the {
Reefology
Post by Reefology »
thanks so much, will try that. while we're at it, is there anyway to make the speed random? I assume some of the modes have random speed built in but i dont know which ones so I just selected all of them hoping to get a varying flow.
Thnaks
Here's some commented code. You will also find this link handy:
http://arduino.cc/en/Reference/HomePage
Look up the different kinds of data types (int, boolean, unsigned long) and also if...else. Also read up on arithmetic, boolean, and comparison operators.
// Declare an integer (a whole number between -32,768 to 32,767) rmode
// and a boolean (false or true, 0 or 1) changeMode which is set to true.
// "static" means only initialize them once.  Otherwise they would be reset
// every time loop loops around.
static int rmode;
// modes[] is an array of bytes (whole numbers between 0 and 255).
byte modes[] = {
  ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre };
// now() is a running tally of seconds since Jan 1, 1970.  It's a big number.
// % is modulo, it returns the remainder from division.  So, if the number of seconds ever
// divided by 600 is 0 (that is, every 600 seconds or 10 minutes) then this is true.
// The || means 'or'.  '==' means 'is equal to'.  So this line says 'if it's been 10 minutes,
// or changeMode is equal to true, then do this stuff in these curly braces.
if (now()%600==0 || changeMode==true) { // Change every 10 mins or if controller rebooted
  changeMode=false;
static unsigned long feeding;  // another variable declaration, type unsigned long
// Difference between '==' and '=':  '==' means 'is equal to' (comparing two things)
// '=' means 'make equal to' as in changing the value of something.  So this line
// says if the menu displayed is equal to FEEDING_MODE, then make the variable 'feeding'
// equal to the number of seconds returned by the function now()
// if right now minus the time feeding was set is less than 3600 (seconds, remember now() returns
// seconds) then do the stuff in the curly braces.
if (now()-feeding<3600) {
  ReefAngel.DCPump.UseMemory=false;  // Turn off portal control of the pumps
  ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read();  // Get the portal pump duration from memory
  ReefAngel.DCPump.Mode=NutrientTransport;    // Manually set the mode to NutrientTransport
// so if the above 'if' isn't true, do the stuff after 'else'.  If this thing is true, do this stuff, else do other stuff
// If it's been more than 60 minutes since feeding time, check to see if now (in seconds) divided by
// the number of seconds per day (86400 to be exact) returns a remainder of less than 43200 (noon)
// or greater than 79200 (10 PM, 2200) then do some stuff
else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.UseMemory=false;  // Turn off portal control of DC Pumps
  ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read();  // Get portal duration from memory location
  ReefAngel.DCPump.Mode=Sine;  // Set the mode to Sine
  ReefAngel.DCPump.Speed=30;   // With a speed of 30
// if the above isn't true, check this
else if (InternalMemory.DCPumpMode_read()==11) {
  // Custom Mode set on portal and nothing else going on (not feeding time, not night time)
  ReefAngel.DCPump.UseMemory=false;  // Turn off portal control of pumps
  ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read();  // Get the duration
// if none of this stuff was true, default to this
else {
  // Do whatever the portal says to do with the DC Pumps
You mean the speed at which the pumps run? Some modes like Else do that automatically. Others, like gyre and sine, go up and down in a set pattern.
Reefology
Post by Reefology »
awesome thank you, the notes are a huge help to me. I'll check out the link as well.
cheers
Reefology
Post by Reefology »
its still stuck in else mode and doesnt change?!
Do you have the portal set to custom?
Reefology
Post by Reefology »
not sure, here is all my code:
    ReefAngel.WaterChangePorts = Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    // Password Protection username:xxxxxxx password:xxxxxxx
    // ReefAngel.Network.WifiAuthentication("xxxxxx,xxxxxxx");
    ReefAngel.DosingPumpRepeat1( Port1 );
    ReefAngel.DosingPumpRepeat2( Port2 );
    ReefAngel.ActinicLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.MoonLights( Port5 );
    ReefAngel.WavemakerRandom( Port6,120,1500 );
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre };
    changeMode=false;
    } else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
    ReefAngel.Portal( "Reefology" );
    ReefAngel.DDNS( "xxxxxxxx" ); // Your DDNS is Reefology-xxxxxxxx.myreefangel.com
Reefology
Post by Reefology »
ok found custom in the portal. but now im wondering what the speed and duration does? doesnt ''custom'' call the code in the custom area thereby overriding speed and duration? asking because now that ive managed to get the modes to changing every 10 minutes, the speed stays the same?
Speed and duration are pulled from the portal. The speed will report in that section as static but you should see the speed change on the screen.
Reefology
Post by Reefology »
this is awesome, im in love with my reef angel and what it is capable of...
now that i have my dc pump up and running, I'm going back to something i put on hold, can someone please look at the code i just put up and tell me why i still cant log into the iphone app using my DDNS?
Make sure you enter reefology-ddns.myreefangel.com
Change the ddns to whatever you choose. Make sure it is - and not _
Reefology
Post by Reefology »
Thanks Roberto but I've checked it too many times to count. Are there other possibilities?
PM me what you are entering. I checked the server and the entries are all there.
I saw 3 entries for you, but they were all same ip address.
Reefology
Post by Reefology »
pm sent
Reefology
Post by Reefology »
current code
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit;
    // Password Protection username:xxxx password:xxxx
    // ReefAngel.Network.WifiAuthentication("xxxx");
    ReefAngel.MoonLights( Port2 );
    ReefAngel.WavemakerRandom1( Port5,120,1500 );
    ReefAngel.WavemakerRandom2( Port6,180,1000 );
    ReefAngel.DCPump.ActinicChannel = AntiSync; // Now pump will be affected by the portal settings
    // Comment out next 2 lines for single dc pump
    // ReefAngel.DCPump.DaylightChannel = Sync; // Now pump will be affected by the portal settings
    // ReefAngel.DCPump.AntiSyncOffset=100;
  // Wavemaker Koralia night mode
    if (hour()>=22 || hour()<7) ReefAngel.Relay.Off (Port5 );
    if (hour()>=23 || hour()<8) ReefAngel.Relay.Off (Port6 );
  // DC pumps
    // To run this code must choose Custom in portal
    static int rmode;
    byte modes[] = { NutrientTransport, Sine, ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%1200==0 || changeMode==true) { // Change every 20 (1200seconds) mins or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    if (now()-feeding<3000) {
    // Continue NutrientTranspot Mode for 45 minutes
    } else if (now()%SECS_PER_DAY<37800 || now()%SECS_PER_DAY>=81000) { // 10:30am / 10:30pm
    ReefAngel.DCPump.Mode=Gyre;
    ReefAngel.DDNS("xxxx"); // Your DDNS is Reefology-xxxx.myreefangel.com
Have another dc pump coming and just want to makes sure i'm ready with code.
Reefology
Post by Reefology »
do i just change this?
Reefology
Post by Reefology »
and does the antisync offset delay 2nd pump by 100 seconds?
No, it allows the antisync channel to be 100% of what it should be. If you have a strong or weaker pump, you could adjust that pump to compensate.
Reefology
Post by Reefology »
sorry, i don't understand.
so if i have a Jebao wp40 and a wp25, how would i use the offset?
What do you want to do with them...if you want to speed one up or slow one down? Which is currently sync/antisync?
Reefology
Post by Reefology »
Yup, that's what I want. So do I remove the offset then? Leave it at 100? Or change it to some other figure?
I gave you two choices...you answered yup. If you want to speed up the antisync channel then make it 125 for a 25% increase. Or make it 75 for a 25% decrease on the one set to antisync
Reefology
Post by Reefology »
thanks for the info Lee :)
i answered "yup" because i'd like to know how to manipulate the fields/data going forward, don't just want to rely on you guys to write code for me (though at times i need you to and certainly do appreciate it). sorry for the confusion :P
No worries just confusing. All good now
Reefology
Post by Reefology »
Hi all,
How do I figure out why I can't upload a sketch when it complies just fine?
This is the error message I'm getting:
Same message I get when try to upload without cable. Can it be a cable issue? It seemed to work yesterday to upload wifitestcode? Sort of...
Make sure you are connecting the cable correctly on RA. It should be all the way to the right and you should have 2 pins unconnected on the left.
Reefology
Post by Reefology »
Hi Roberto,
Yes thanks, I've uploaded sketches many times so it's definitely not that. Any other ideas?
Reefology
Post by Reefology »
 // DC pumps
    static int rmode;
    changeMode=false;
hi, based on the code above, I don't understand why my pwm channels have been at 0 for the past 45 mins? can someone help me figure out what I've done wrong? thanks
Reefology
Post by Reefology »
 // DC pumps
    static int rmode;
    changeMode=false;
