Reefology's code
Reefology
Re: Reefology's code
Post by Reefology »
this is awesome, im in love with my reef angel and what it is capable of...
now that i have my dc pump up and running, I'm going back to something i put on hold, can someone please look at the code i just put up and tell me why i still cant log into the iphone app using my DDNS?
Make sure you enter reefology-ddns.myreefangel.com
Change the ddns to whatever you choose. Make sure it is - and not _
Reefology
Post by Reefology »
Thanks Roberto but I've checked it too many times to count. Are there other possibilities?
PM me what you are entering. I checked the server and the entries are all there.
I saw 3 entries for you, but they were all same ip address.
Reefology
Post by Reefology »
pm sent
Reefology
Post by Reefology »
current code
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    // Password Protection username:xxxx password:xxxx
    // ReefAngel.Network.WifiAuthentication("xxxx");
    ReefAngel.DosingPumpRepeat1( Port1 );
    ReefAngel.MoonLights( Port2 );
    ReefAngel.ActinicLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.WavemakerRandom1( Port5,120,1500 );
    ReefAngel.WavemakerRandom2( Port6,180,1000 );
    ReefAngel.DCPump.ActinicChannel = AntiSync; // Now pump will be affected by the portal settings
    // Comment out next 2 lines for single dc pump
    // ReefAngel.DCPump.DaylightChannel = Sync; // Now pump will be affected by the portal settings
    // ReefAngel.DCPump.AntiSyncOffset=100;
  // Wavemaker Koralia night mode
    if (hour()>=22 || hour()<7) ReefAngel.Relay.Off (Port5 );
    if (hour()>=23 || hour()<8) ReefAngel.Relay.Off (Port6 );
  // DC pumps
    // To run this code must choose Custom in portal
    static int rmode;
    byte modes[] = { NutrientTransport, Sine, ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%1200==0 || changeMode==true) { // Change every 20 (1200seconds) mins or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    static unsigned long feeding;
    if (now()-feeding<3000) {
    // Continue NutrientTranspot Mode for 45 minutes
    } else if (now()%SECS_PER_DAY<37800 || now()%SECS_PER_DAY>=81000) { // 10:30am / 10:30pm
    // Night mode (go to 30%)
    ReefAngel.DCPump.Mode=Gyre;
    ReefAngel.DCPump.Speed=30;
    ReefAngel.Portal( "Reefology" );
    ReefAngel.DDNS("xxxx"); // Your DDNS is Reefology-xxxx.myreefangel.com
Have another dc pump coming and just want to makes sure i'm ready with code.
Reefology
Post by Reefology »
do i just change this?
Reefology
Post by Reefology »
and does the antisync offset delay 2nd pump by 100 seconds?
No, it allows the antisync channel to be 100% of what it should be. If you have a strong or weaker pump, you could adjust that pump to compensate.
Reefology
Post by Reefology »
sorry, i don't understand.
so if i have a Jebao wp40 and a wp25, how would i use the offset?
What do you want to do with them...if you want to speed one up or slow one down? Which is currently sync/antisync?
Reefology
Post by Reefology »
Yup, that's what I want. So do I remove the offset then? Leave it at 100? Or change it to some other figure?
I gave you two choices...you answered yup. If you want to speed up the antisync channel then make it 125 for a 25% increase. Or make it 75 for a 25% decrease on the one set to antisync
Reefology
Post by Reefology »
thanks for the info Lee :)
i answered "yup" because i'd like to know how to manipulate the fields/data going forward, don't just want to rely on you guys to write code for me (though at times i need you to and certainly do appreciate it). sorry for the confusion :P
No worries just confusing. All good now
Reefology
Post by Reefology »
Hi all,
How do I figure out why I can't upload a sketch when it complies just fine?
This is the error message I'm getting:
Same message I get when try to upload without cable. Can it be a cable issue? It seemed to work yesterday to upload wifitestcode? Sort of...
Make sure you are connecting the cable correctly on RA. It should be all the way to the right and you should have 2 pins unconnected on the left.
Reefology
Post by Reefology »
Hi Roberto,
Yes thanks, I've uploaded sketches many times so it's definitely not that. Any other ideas?
Reefology
Post by Reefology »
 // DC pumps
    static int rmode;
    changeMode=false;
hi, based on the code above, I don't understand why my pwm channels have been at 0 for the past 45 mins? can someone help me figure out what I've done wrong? thanks
Reefology
Post by Reefology »
 // DC pumps
    static int rmode;
    changeMode=false;
Reefology
Post by Reefology »
 // DC pumps
    static int rmode;
    changeMode=false;
What mode do you see in the screen?
Reefology
Post by Reefology »
not sure which screen you're referring to but in the portal, the internal memory keeps getting reset to 0's for both speed and duration? currently the mode alternates but it was set up in custom??
The RA screen. Move the joystick to the right or left.
Or are you using a custom screen?
Reefology
Post by Reefology »
it says normal mode. what is that? don't see it listed in the portal as a mode.
Normal?
Are you sure you are in the RF screen?
Can you send a picture?
Reefology
Post by Reefology »
sorry Roberto, the mode is gyre, duration is 15 and speed is 30
Which channels did you assign for DCPump?
Reefology
Post by Reefology »
lol, I just logged in to tell you i figured it out...had the actinic channel set to None and of course thought I had the pump wired to daylights :p
thanks Roberto
Reefology
Post by Reefology »
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.DayLights( Port2 );
    ReefAngel.StandardLights( Port5, 19,0,7,0);
    ReefAngel.DosingPumpRepeat1( Port6 );
    ReefAngel.DosingPumpRepeat2( Port7 );
    ReefAngel.DosingPumpRepeat3( Port8 );
    ReefAngel.DCPump.LowATOChannel = Sync; // WP40
    ReefAngel.DCPump.HighATOChannel = AntiSync; // SW 8
    ReefAngel.DCPump.AntiSyncOffset=125;
    // DC pumps
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%3600==0 || changeMode==true) { // Change every 60 mins (3600seconds) or controller reboot
    changeMode=false;
    // Continue NutrientTranspot Mode for 30 minutes after feeding
    if (now()-feeding<1800) {
    ReefAngel.DCPump.Speed=80;
    } else if (now()%SECS_PER_DAY>25200 && now()%SECS_PER_DAY<=68400) { // 7am to 7pm
Can someone here please tell me why my Jebao wavemaker pump is running full throttle constantly on the ATO high? the ATO low is working great. in fact I made an adaptor to run both pumps on my ATO low and they're working but I'd really like to get the antisync working. The code I'm using in the meantime is below.
thanks
    ReefAngel.StandardLights( Port5 );
    ReefAngel.DCPump.LowATOChannel = Sync; // WP40 & SW 8
    ReefAngel.DCPump.HighATOChannel = None; //
    // DC pumps....................................
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, Else, Gyre, NutrientTransport };
    if (now()%1800==0 || changeMode==true)  // Change every 30 mins (1800seconds) or controller reboot
    changeMode=false;
    ReefAngel.DCPump.Mode=ReefCrest;
    // Night/Quiet mode
      else if (hour()>=2 && hour()<8 ) // 2am to 8am
    ReefAngel.DCPump.SetMode( Sine,35,10 );
      else if (hour()>=15 && hour()<19) // 3pm and 7pm
    ReefAngel.DCPump.SetMode( LongPulse,30,1 );
    //Storm mode
    else if (hour()>=1 && hour()<2) // 1am and 2am
    ReefAngel.DCPump.SetMode( Else,80,15 );
      else if (hour()>=11 && hour()<12) // 11am and 12pm
    ReefAngel.DCPump.SetMode( LongPulse,95,2 );
    else if (hour()>=21 && hour()<22) // 9pm and 10pm
    ReefAngel.DCPump.SetMode( ReefCrest,85,15 );
