Reefology's code
PostPosted: Mon Feb 09, 2015 6:20 am
What do you want to do with them...if you want to speed one up or slow one down? Which is currently sync/antisync?
PostPosted: Mon Feb 09, 2015 7:30 am
Yup, that's what I want. So do I remove the offset then? Leave it at 100? Or change it to some other figure?
PostPosted: Mon Feb 09, 2015 8:56 am
I gave you two choices...you answered yup. If you want to speed up the antisync channel then make it 125 for a 25% increase. Or make it 75 for a 25% decrease on the one set to antisync
PostPosted: Mon Feb 09, 2015 11:55 am
thanks for the info Lee :)
i answered "yup" because i'd like to know how to manipulate the fields/data going forward, don't just want to rely on you guys to write code for me (though at times i need you to and certainly do appreciate it). sorry for the confusion :P
PostPosted: Mon Feb 09, 2015 4:05 pm
No worries just confusing. All good now
PostPosted: Wed Nov 02, 2016 8:13 am
Hi all,
How do I figure out why I can't upload a sketch when it complies just fine?
This is the error message I'm getting:
Same message I get when try to upload without cable. Can it be a cable issue? It seemed to work yesterday to upload wifitestcode? Sort of...
PostPosted: Wed Nov 02, 2016 9:31 am
Make sure you are connecting the cable correctly on RA. It should be all the way to the right and you should have 2 pins unconnected on the left.
PostPosted: Wed Nov 02, 2016 2:03 pm
Hi Roberto,
Yes thanks, I've uploaded sketches many times so it's definitely not that. Any other ideas?
PostPosted: Sat Nov 26, 2016 3:29 pm
 // DC pumps
    // To run this code must choose Custom in portal
    static int rmode;
    byte modes[] = { NutrientTransport, Sine, ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%1200==0 || changeMode==true) { // Change every 20 (1200seconds) mins or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    static unsigned long feeding;
    if (now()-feeding<3000) {
    // Continue NutrientTranspot Mode for 45 minutes
    } else if (now()%SECS_PER_DAY<37800 || now()%SECS_PER_DAY>=81000) { // 10:30am / 10:30pm
    // Night mode (go to 30%)
    ReefAngel.DCPump.Mode=Gyre;
    ReefAngel.DCPump.Speed=30;
hi, based on the code above, I don't understand why my pwm channels have been at 0 for the past 45 mins? can someone help me figure out what I've done wrong? thanks
 // DC pumps
    static int rmode;
    changeMode=false;
Return to Ask anything here
