Reefology's code
PostPosted: Sat Nov 26, 2016 3:30 pm
 // DC pumps
    // To run this code must choose Custom in portal
    static int rmode;
    byte modes[] = { NutrientTransport, Sine, ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%1200==0 || changeMode==true) { // Change every 20 (1200seconds) mins or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    static unsigned long feeding;
    if (now()-feeding<3000) {
    // Continue NutrientTranspot Mode for 45 minutes
    } else if (now()%SECS_PER_DAY<37800 || now()%SECS_PER_DAY>=81000) { // 10:30am / 10:30pm
    // Night mode (go to 30%)
    ReefAngel.DCPump.Mode=Gyre;
    ReefAngel.DCPump.Speed=30;
hi, based on the code above, I don't understand why my pwm channels have been at 0 for the past 45 mins? can someone help me figure out what I've done wrong? thanks
PostPosted: Sat Nov 26, 2016 4:41 pm
What mode do you see in the screen?
PostPosted: Sat Nov 26, 2016 10:04 pm
not sure which screen you're referring to but in the portal, the internal memory keeps getting reset to 0's for both speed and duration? currently the mode alternates but it was set up in custom??
PostPosted: Sat Nov 26, 2016 11:49 pm
The RA screen. Move the joystick to the right or left.
Or are you using a custom screen?
PostPosted: Sun Nov 27, 2016 6:04 pm
it says normal mode. what is that? don't see it listed in the portal as a mode.
PostPosted: Sun Nov 27, 2016 6:51 pm
Normal?
Are you sure you are in the RF screen?
Can you send a picture?
PostPosted: Mon Nov 28, 2016 5:38 pm
sorry Roberto, the mode is gyre, duration is 15 and speed is 30
PostPosted: Mon Nov 28, 2016 7:25 pm
Which channels did you assign for DCPump?
PostPosted: Mon Nov 28, 2016 7:38 pm
lol, I just logged in to tell you i figured it out...had the actinic channel set to None and of course thought I had the pump wired to daylights :p
thanks Roberto
PostPosted: Wed Jan 11, 2017 3:56 pm
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.DayLights( Port2 );
    ReefAngel.StandardLights( Port5, 19,0,7,0);
    ReefAngel.DosingPumpRepeat1( Port6 );
    ReefAngel.DosingPumpRepeat2( Port7 );
    ReefAngel.DosingPumpRepeat3( Port8 );
    ReefAngel.DCPump.LowATOChannel = Sync; // WP40
    ReefAngel.DCPump.HighATOChannel = AntiSync; // SW 8
    ReefAngel.DCPump.AntiSyncOffset=125;
    // DC pumps
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%3600==0 || changeMode==true) { // Change every 60 mins (3600seconds) or controller reboot
    changeMode=false;
    // Continue NutrientTranspot Mode for 30 minutes after feeding
    if (now()-feeding<1800) {
    ReefAngel.DCPump.Speed=80;
    } else if (now()%SECS_PER_DAY>25200 && now()%SECS_PER_DAY<=68400) { // 7am to 7pm
Can someone here please tell me why my Jebao wavemaker pump is running full throttle constantly on the ATO high? the ATO low is working great. in fact I made an adaptor to run both pumps on my ATO low and they're working but I'd really like to get the antisync working. The code I'm using in the meantime is below.
thanks
    ReefAngel.StandardLights( Port5 );
    ReefAngel.DCPump.LowATOChannel = Sync; // WP40 & SW 8
    ReefAngel.DCPump.HighATOChannel = None; //
    // DC pumps....................................
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, Else, Gyre, NutrientTransport };
    if (now()%1800==0 || changeMode==true)  // Change every 30 mins (1800seconds) or controller reboot
    changeMode=false;
    ReefAngel.DCPump.Mode=ReefCrest;
    // Night/Quiet mode
      else if (hour()>=2 && hour()<8 ) // 2am to 8am
    ReefAngel.DCPump.SetMode( Sine,35,10 );
      else if (hour()>=15 && hour()<19) // 3pm and 7pm
    ReefAngel.DCPump.SetMode( LongPulse,30,1 );
    //Storm mode
    else if (hour()>=1 && hour()<2) // 1am and 2am
    ReefAngel.DCPump.SetMode( Else,80,15 );
      else if (hour()>=11 && hour()<12) // 11am and 12pm
    ReefAngel.DCPump.SetMode( LongPulse,95,2 );
    else if (hour()>=21 && hour()<22) // 9pm and 10pm
    ReefAngel.DCPump.SetMode( ReefCrest,85,15 );
Return to Ask anything here
