Hi,
The temp probe, PWM, float switch connectors look like standard parts.
Does anyone have the specifics on the part numbers from some major supplier? Mouser/Digikey ?
Much thanks,
Rob
Sourcing Connectors for Temp/PWM/Float
Re: Sourcing Connectors for Temp/PWM/Float
Not sure about the PWM and float switch connectors. I use ones I bought from RA or make my own out of header strips.
The temp probes use a standard 3 pin computer fan connector.
