I just bought the RA+ w/ WiFi during the Thanksgiving Sale a few months ago. And I just put it to use starting Jan. 2nd. So it hasn't even been a month since I actually even used it.lnevo wrote:I would try a different probe. They really dont as long as people would think
ph reading off
Re: ph reading off
Re: ph reading off
I'll get this # when I get home in a few hours. Hopefully we can get to the bottom of this.rimai wrote:I'm thinking the problem was the calibration.
If you go into calibration mode with the probe in your tank, what value do you get?
Re: ph reading off
Ph 7.93, calibration menu shows 600
Re: ph reading off
I think your calibration numbers are off by around 12
Try adding this to setup() after ReefAngel.Init()
ReefAngel.PHMin=500;
ReefAngel.PHMax=783;
Re: ph reading off
Thanks Roberto, now its reading 8.04.rimai wrote:I think your calibration numbers are off by around 12
Try adding this to setup() after ReefAngel.Init()Code: Select all
ReefAngel.PHMin=500; ReefAngel.PHMax=783;
Re: ph reading off
Hi Roberto,
My PH reading went crazy this morning, at 6:20am it showed a 2.48PH!! Nothing has changed. Why am I having such a difficult time with my ph reading??
Re: ph reading off
Ok, never mind, found out my return pump is causing it all of a sudden, which is really strange because nothing has changed with it. Why all of a sudden my return pump would leak so much stray voltage to cause such a problem
Re: ph reading off
Actually, I got a hold of a voltage meter and did some more testing. It was not my return pump like I assumed, it was the ATO switch... I haven't even had this running for 2 months and it has already went bad on me. Is that normal??
