Motorola router
Re: Motorola router
Does the web portal work?
What address are you using on the Android app? If it starts with 192 it won't work outside your home network.
Re: Motorola router
The web portal works fine. I'm using the address that it shows in the web portal. Is this the wrong one?
Re: Motorola router
No, that should be correct.
Which Android app are you using?
Re: Motorola router
OK, lets start at the beginning. Leave Reef Angel Status set to "Controller". Set the "Home" profile to your 192 IP address, with the port as 2000. Set the "Away" profile to the IP the portal gives you and the port as 2000. Do a refresh under each profile and tell me what happens (assuming you're home on your home WiFi).
Re: Motorola router
I got an error 14 when I refreshed on the home profile and when I was in the away profile it refreshed normally.
Re: Motorola router
What's error 14? Is it consistent?
Re: Motorola router
It says unknown host. Then it gives me the 192 IP address. Yes, every time I hit refresh while in the home profile, it does it.
Re: Motorola router
You're on your home Wifi?
Re: Motorola router
Doesn't make any sense. The 192 address is the same one you have set to ReefAngelWifi in your router?
Re: Motorola router
Just to make sure, when you asked me to put my 192 IP address, you were asking for my router's IP address?
Re: Motorola router
I checked my router and I put in the IP address that I reserved for the RA wifi.
Re: Motorola router
Re: Motorola router
Try rebooting your router. Other than that I have no idea. Maybe I'm missing something fundamental.
Does the "Away" profile work as expected?
Re: Motorola router
If I set the device to controller and I'm in the away profile, it refreshes fine and I can toggle things off and on. If I set the device to portal and I'm in the away profile I can refresh it just fine but I can't toggle anything.
Re: Motorola router
That's to be expected. Leave it on controller. I have no clue on the 192 address. Maybe someone else can chime in.
You need to set up the DDNS service. This is so if your cable company changes your external IP address the app can still find your RA. See this thread.
http://forum.reefangel.com/viewtopic.php?f=20&t=4754
You would use this address in place of the one the portal is reporting. I.e., instead of the portal address you will use ismaclst-whatever.myreefangel.com in the "Away" profile in the app (or "Home", if you prefer).
Re: Motorola router
OK, thanks for all of your help!
Re: Motorola router
You're welcome!
