Motorola router
Re: Motorola router
Doesn't make any sense. The 192 address is the same one you have set to ReefAngelWifi in your router?
Re: Motorola router
Just to make sure, when you asked me to put my 192 IP address, you were asking for my router's IP address?
Re: Motorola router
I checked my router and I put in the IP address that I reserved for the RA wifi.
Re: Motorola router
Re: Motorola router
Try rebooting your router. Other than that I have no idea. Maybe I'm missing something fundamental.
Does the "Away" profile work as expected?
Re: Motorola router
If I set the device to controller and I'm in the away profile, it refreshes fine and I can toggle things off and on. If I set the device to portal and I'm in the away profile I can refresh it just fine but I can't toggle anything.
Re: Motorola router
That's to be expected. Leave it on controller. I have no clue on the 192 address. Maybe someone else can chime in.
You need to set up the DDNS service. This is so if your cable company changes your external IP address the app can still find your RA. See this thread.
http://forum.reefangel.com/viewtopic.php?f=20&t=4754
You would use this address in place of the one the portal is reporting. I.e., instead of the portal address you will use ismaclst-whatever.myreefangel.com in the "Away" profile in the app (or "Home", if you prefer).
Re: Motorola router
OK, thanks for all of your help!
Re: Motorola router
You're welcome!
