reduce Feeding Mode time
How do I reduce the feeding time? Right now it looks like it is set for 999 seconds, I would like to reduce it to 10 min. (600 seconds). Also, is there any way to code to activate one pump, then delay for a minute to activate another pump?
Re: reduce Feeding Mode time
http://www.xxx.yyy.zzz:2000/mb214,600
For your pumps is that something you want to do just during feeding mode? Basically your talking about long pulse mode with the duration set to 60
Yes, just during feeding mode. First I want to reduce the duration of the feeding mode, then I would like 1 pump to start then delay the second pump for a minute. Because when both start at the same time it always scare the fish.lnevo wrote:http://www.xxx.yyy.zzz:2000/mb214,600
