reef angel for reptile cage
theking2a
Post by theking2a »
Hi
would like to use a reef angel in my reptile cages
could the reef angel do the following thing or do I need a plus
3 temp probes
control 3 misters
control actuator
I know I will need a Reef Angel I/o Expansion
my plans when its warm actuator will lift the roof off
and when it get very hot the misters will go on
I have 3 cage in 1 so I need 3 temp probes and 3 misters
would think is will :? work
thanks
Matthew
Re: reef angel for reptile cage
RA+. You probably could use a standard RA, but the memory is limited and you'd be limited to old libraries. It would be fairly frustrating in the long run.
Why are you thinking you'd need the I/O expansion?
theking2a
Post by theking2a »
I thought I need a I/O box to connect the switch to turn on the mister and actuator
Do you think there is a better solution
thanks
Matthew
You could just plug their power supplies into the relay box and turn on the appropriate relays when temps are reached.
Smotz
Post by Smotz »
theking2a wrote:Hi
3 temp probes
control 3 misters
control actuator
thanks
Matthew
was thinking of doing this same thing.
theking2a
Post by theking2a »
Hi
I have been researching actuator
the one that I want to use, use a switch to raise the actuator and another switch to lower the actuator
That's they I thought I need a I/O to do the switching can the reef angel to this
thanks
Matthew
Can you post a link to the actuator?
