Auto Water Change
PostPosted: Wed Sep 23, 2015 5:47 am
I have two litermeter pumps and have it pump water in/out 150 times a day. What you need to is see how much each water pumps per unit of time. Then you can calculate how long each pump needs to run and how many times a day you need it to turn on in order to change the desired amount of water. I have mine change water every 9 minutes (150x a day). The nice thing about this is that the new saltwater does not need to be heated as you are changing very little at a time.
Check out the link below for more info on the code I use:
http://forum.reefangel.com/viewtopic.php?f=12&t=5158
A special thanks goes out again for the help I received to make this a possibility.
PostPosted: Wed Sep 23, 2015 7:31 am
Rodasphoto wrote:I have two litermeter pumps and have it pump water in/out 150 times a day. What you need to is see how much each water pumps per unit of time. Then you can calculate how long each pump needs to run and how many times a day you need it to turn on in order to change the desired amount of water. I have mine change water every 9 minutes (150x a day). The nice thing about this is that the new saltwater does not need to be heated as you are changing very little at a time.
Thank you for your response. Can you post a link to the pumps you use so I can make sure I look at the right thing?
PostPosted: Wed Sep 23, 2015 7:51 am
http://spectrapure.com/LiterMeter-III-P ... ystem-115V
Here you go. Amazing little pumps!
PostPosted: Mon Sep 28, 2015 5:59 pm
I've been using the litermeter for 3 months now.... Rock solid...not a single spike in salinity...
Sent from my XT1254 using Tapatalk
Previous
Return to Ask anything here
