Hello,
I just recently upgraded to a 180G tank.
For my upgrade I'm buying new light fixtures and going with 3 Dimmable ONYX fixtures from RAPID LED.
I wanted to see if anyone has any experience connecting 3 of these units to the RA controller.
Do I just need 3 sets of the onyx to bare wire or do I need a combination of onyx to bare wire and Onyx to Onyx Wiring Harness?
Any help will be greatly appreciated.
Brandon
RAPID LED ONYX WIRES
Re: RAPID LED ONYX WIRES
Depends if your gonna be connecting them together or controlling each one individually. If you want to plug one to the ra and the. Daisy chain you'd need a combo. If you want to connect them all to two dimming ports on the RA you can do either cabling. If you are gonna connect them to a dimming module then bare wire for all 3
Thank You!lnevo wrote:Depends if your gonna be connecting them together or controlling each one individually. If you want to plug one to the ra and the. Daisy chain you'd need a combo. If you want to connect them all to two dimming ports on the RA you can do either cabling. If you are gonna connect them to a dimming module then bare wire for all 3
