Jebao wavemaker
PostPosted: Wed Nov 18, 2015 9:25 pm
my question is, if I use the jebao cable is there a way to have the pumps on a certain mode with a certain max percentage be able to run lets say from 8 am to 9 pm and while running that certain mode.. be able to ramp up and down through the percentages with it hitting max at mid day?
PostPosted: Thu Nov 19, 2015 3:56 am
Yup. I think you could use the PWMSlope function and feed it to the pump function.
PostPosted: Thu Nov 19, 2015 6:51 am
Ok, I saw that you could tie it in with the parabola selection of the actinic or white channel. I am a potential buyer but am curious of things like this before I pull the trigger as im not great at codes.
PostPosted: Thu Nov 19, 2015 8:25 am
You could do it independently of the lights as well.
PostPosted: Thu Nov 19, 2015 9:51 am
Yeah, you can basically create whatever waveform you can think of.
We have the basic waveforms like the ecotech waveforms and to add to that, we also have slopes, parabolas, sigmoids and else wafeforms. There may be more that I can't think of.
PostPosted: Thu Nov 19, 2015 2:04 pm
great! will play with it when I get it in I will come here for help. I can think of some advanced usages for it but no sense in asking now, im sure its more than capable.
PostPosted: Mon Nov 23, 2015 7:52 am
I am generating my code in anticipation of my order, if I post here could you help me develop a code to add in to perform the way I would like.
I am thinking:
from 9 am to 7 pm - alternate back and forth randomly maybe reef crest? (I can set a % that I would like it to stay at, and it can choose to go something like 20% over or under.. or anywhere in between that 40 percent range at its choice)
from 7pm - 9am - alternate back and forth for 20 minutes at a time at the lowest possible percentage
is something like that possible?
PostPosted: Mon Nov 23, 2015 8:21 am
yes
PostPosted: Mon Nov 23, 2015 12:50 pm
    ReefAngel.FeedingModePorts = Port2Bit;
    ReefAngel.WaterChangePorts = Port2Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardHeater( Port1,764,771 );
    ReefAngel.SingleATO( true,Port2,200,0 );
    ReefAngel.MHLights( Port3,21,0,9,0,10 );
    ReefAngel.StandardLights( Port4,9,0,19,0 );
    ReefAngel.MHLights( Port8,12,0,15,0,7 );
    ReefAngel.PWM.SetDaylight( PWMParabola(9,0,20,0,15,48,15) );
    ReefAngel.PWM.SetActinic( PWMParabola(9,0,20,0,15,48,15) );
    ReefAngel.DCPump.SetMode( ReefCrest,50,10 );
    ReefAngel.AddWifi();
Return to Ask anything here
