Icecap Module
PostPosted: Sun Feb 28, 2016 2:44 pm
I have the maxspect gyre and was thinking about purchasing the Icecap module to go with it. Has anyone else bought this? Does it come with the cable you need to connect to the RA? I'm assuming you can use any of the DC pump modes?
PostPosted: Sun Feb 28, 2016 4:27 pm
It might come with the cable to connect to apex. You'd have to cut off the ethernet jack and connect the wires to the dimming module or splice it to the dimming connector cable. You're alternative is to take an ethernet jack outlet and connect the wires from that to your dimming module / dimming leads.
It should be able to use the DC Pump modes, the issue is how will it react. Also keep in mind that one of the connections controls speed, the other direction, so you'll need some manual code to control the direction and keep in mind that it's not a usual powerhead so the behavior may be different with our modes.
PostPosted: Sun Feb 28, 2016 5:03 pm
Ok, thanks. I don't use the reverse flow so I don't need to buy the special cable. Roberto, what code are you using for your gyre?
PostPosted: Sun Feb 28, 2016 5:47 pm
Sorry, I was actually never able to set it up yet.
I moved and I'm kind of remodeling the house, so I took my tank to the office and I'm waiting to finish my house to setup a new tank and install the Gyre pump.
PostPosted: Sun Feb 28, 2016 5:49 pm
Ismaclst wrote:I have the maxspect gyre and was thinking about purchasing the Icecap module to go with it. Has anyone else bought this? Does it come with the cable you need to connect to the RA? I'm assuming you can use any of the DC pump modes?
You should be able to use the DCPump modes.
The Kessil cable in the webstore should be able to be used with the Icecap module too :)
PostPosted: Mon Feb 29, 2016 11:11 am
Ok, thanks. What mode are you guys running at night after the lights go out? I wanted something that is more gentle at night and during the day I was planning on using else mode.
PostPosted: Mon Feb 29, 2016 1:20 pm
I'm using the Tide function to manage flow with the Maxspect/Icecap. Here is my code to make this happen:
In your init:
    tide.Init(40,10,30);
    tide.SetWaveLength(12+SECS_PER_HOUR);
Then call this function from your loop:
void setMaxspect()
  int reverse_speed=0;
  int forward_speed=45;
 if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
   forward_speed = NutrientTransportMode(25,50,1500,false);
   reverse_speed = 0;
    forward_speed = tide.CalcTide();
#if debug_flow == 1
  Serial.print("Forward Speed: ");
  Serial.print(forward_speed);
  Serial.print(" Reverse Speed: ");
  Serial.print(reverse_speed);
  Serial.println();
#endif
  ReefAngel.PWM.SetChannel(2,reverse_speed);  // set the pump direction
  ReefAngel.PWM.SetChannel(1,forward_speed);    // set the pump speed
Hope this helps.
-LeoD
PostPosted: Mon Feb 29, 2016 2:53 pm
oftheangels wrote:I'm using the Tide function to manage flow with the Maxspect/Icecap. Here is my code to make this happen:
In your init:
void setMaxspect()
   reverse_speed = 0;
#if debug_flow == 1
  Serial.println();
#endif
Hope this helps.
-LeoD
How well does the tide function work with the gyre? Is it as random as the else mode? Would you say there is a big difference from the stock controller to the RA?
PostPosted: Mon Feb 29, 2016 3:27 pm
The tide function works pretty well actually. The transitions are much gentler than say pulse mode. Really the only two modes I used with the standard controller were gyre and pulse...
For a while I was using this:
forward_speed = ShortPulseMode(tide.CalcTide() -10, tide.CalcTide(), 5000, false);
This adds a pulse on the tide... I may switch back to this at some point. I've only been running with straight tide for a few days but my corals seem to love it and the sand in my tank is staying put ;^). Also, I did use the gyre effect like this:
   reverse_speed = ShortPulseMode(0,100,10000,false);
   if (reverse_speed == 100)
     // while we are going in reverse increase the speed to 45-60
     forward_speed = ShortPulseMode(30,60,5000,false);
     // while we are going forward set speed to 25-40 to keep
     // from blowing corals off the rocks
     forward_speed = ShortPulseMode(25,40,5000, false);
What this does is switch directions (forward/reverse) every 10 seconds and runs a pulse on top of that (every 5 seconds)... There are so many possibilities (which is why I love the RA).
-LeoD
PostPosted: Mon Feb 29, 2016 3:44 pm
I should also add that I am working on a generic function that uses all of the above tricks but uses memory locations for:
mode: pulse, gyre
usetide: true/false
minspeed
maxspeed
pulsecycle
gyrecycle
I will post it the source once I get it all working satisfactory. It will be nice to switch modes and speeds like the builtin maxspect controller does.
-LeoD
Next
Return to Ask anything here
