Icecap Module
PostPosted: Mon Feb 29, 2016 4:01 pm
Great, thanks. Could you post your whole code?
PostPosted: Mon Feb 29, 2016 4:22 pm
Here you go. Keep in mind I'm a RA newbie:
#include <Tide.h>
#include <SunLocation.h>
#define debug_flow 1
#define debug_lights 1
#define Return 1
#define Skimmer 2
#define Heater 3
#define SumpLight 4
#define Unused 6
#define Scrubber 5
#define PowerStrip 7
#define ATO 8
#define SumpTemp T1_PROBE
#define DisplayTemp T2_PROBE
Tide tide;
SunLocation sunLocation;
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit;
    ReefAngel.CustomLabels[0]="Return";
    ReefAngel.CustomLabels[2]="Heater";
    ReefAngel.CustomLabels[3]="Fuge Light";
    ReefAngel.CustomLabels[4]="Unused";
    ReefAngel.CustomLabels[5]="Scrubber";
    ReefAngel.CustomLabels[6]="Power Strip";
    ReefAngel.CustomLabels[7]="ATO";
    tide.Init(40,10,30);
    tide.SetWaveLength(12+SECS_PER_HOUR);
    sunLocation.Init(25.7753,80.2089);
    sunLocation.SetOffset(8,0,8,0);
    ReefAngel.Relay.DelayedOn( Port2 );
    ReefAngel.StandardHeater( Port3, 785, 805 );
    ReefAngel.StandardLights( Port4, 20,0,9,0);
    //setVortech();
    // turn the scrubber led on at 5pm and off at 5am
    ReefAngel.StandardLights(Port5,17,0,5,0);
    sunLocation.CheckAndUpdate();
    setLED();
    setMoon();
    setMaxspect();
    ReefAngel.Portal( "oftheangels" );
void setLED()
#if debug_flow == 1
  Serial.print("Rise Hour: ");
  Serial.print(sunLocation.GetRiseHour());
  Serial.print(" Rise Minute: ");
  Serial.print(sunLocation.GetRiseMinute());
  Serial.print(" Set Hour: ");
  Serial.print(sunLocation.GetSetHour());
  Serial.print(" Set Minute: ");
  Serial.print(sunLocation.GetSetMinute());
  Serial.println();
#endif
    ReefAngel.PWM.SetActinic(PWMParabola(sunLocation.GetRiseHour(),sunLocation.GetRiseMinute(),sunLocation.GetSetHour() ,sunLocation.GetSetMinute(),0,50,0));
    ReefAngel.PWM.SetDaylight(PWMParabola(sunLocation.GetRiseHour(),sunLocation.GetRiseMinute(),sunLocation.GetSetHour(),sunLocation.GetSetMinute(),10,60,0));
void setMoon()
#ifdef debug_lights == 1
  Serial.print("Daylight: ");
  Serial.print(sunLocation.IsDaytime());
  Serial.print(" MoonPhase: ");
  Serial.print(MoonPhase());
  Serial.println();
#endif
  if (sunLocation.IsDaytime())
    ReefAngel.PWM.SetChannel(0, 0);
    ReefAngel.PWM.SetChannel( 0, MoonPhase() );
void setVortech()
    // Pumps for night mode, start with lagoon, short pulse most of the day
  if (ReefAngel.DisplayedMenu!=FEEDING_MODE || ReefAngel.DisplayedMenu!=WATERCHANGE_MODE)
    if (hour() > 9 || hour() < 17)
      ReefAngel.RF.SetMode(ReefCrest,40,0);
      ReefAngel.RF.SetMode(LongWave, 40, 0);
void setMaxspect()
  int reverse_speed=0;
  int forward_speed=45;
 if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
   forward_speed = NutrientTransportMode(25,50,1500,false);
   reverse_speed = 0;
 } else if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
   // shut off maxspect during water changes.
   forward_speed = 0;
   reverse_speed = 0;
   // swap between forward and reverse every 10 seconds
#if 0
   reverse_speed = ShortPulseMode(0,100,10000,false);
   if (reverse_speed == 100)
     // while we are going in reverse increase the speed to 45-60
     forward_speed = ShortPulseMode(30,60,5000,false);
     // while we are going forward set speed to 25-40 to keep
     // from blowing corals off the rocks
     forward_speed = ShortPulseMode(25,40,5000, false);
#endif
    forward_speed = tide.CalcTide();
#if debug_flow == 1
  Serial.print("Forward Speed: ");
  Serial.print(forward_speed);
  Serial.print(" Reverse Speed: ");
  Serial.print(reverse_speed);
  Serial.println();
#endif
  ReefAngel.PWM.SetChannel(2,reverse_speed);  // set the pump direction
  ReefAngel.PWM.SetChannel(1,forward_speed);    // set the pump speed
PostPosted: Mon Feb 29, 2016 6:18 pm
rimai wrote:
Ismaclst wrote:I have the maxspect gyre and was thinking about purchasing the Icecap module to go with it. Has anyone else bought this? Does it come with the cable you need to connect to the RA? I'm assuming you can use any of the DC pump modes?
You should be able to use the DCPump modes.
The Kessil cable in the webstore should be able to be used with the Icecap module too :)
Will this cable allow forward and reverse?
PostPosted: Mon Feb 29, 2016 6:28 pm
oftheangels wrote:Here you go. Keep in mind I'm a RA newbie:
#include <Tide.h>
#define Return 1
#define Skimmer 2
#define Heater 3
#define SumpLight 4
#define Unused 6
#define Scrubber 5
#define ATO 8
Tide tide;
    //setVortech();
    setLED();
    setMoon();
    setMaxspect();
void setLED()
#if debug_flow == 1
  Serial.println();
#endif
void setMoon()
  Serial.println();
#endif
void setVortech()
void setMaxspect()
   reverse_speed = 0;
   forward_speed = 0;
   reverse_speed = 0;
#if 0
#endif
#if debug_flow == 1
  Serial.println();
#endif
Thanks for your help. I was getting some errors when I added what you told me to. I figured out that I needed to add these, too.
Tide tide;
#include <Tide.h>
PostPosted: Mon Feb 29, 2016 6:32 pm
Yes
PostPosted: Mon Feb 29, 2016 6:34 pm
Great, thanks.
PostPosted: Mon Feb 29, 2016 7:28 pm
#include <Tide.h>
#define Return 1
#define Skimmer 2
#define Heater 3
#define SumpLight 4
#define Unused 6
#define Scrubber 5
#define ATO 8
Tide tide;
    //setVortech();
    setLED();
    setMoon();
    setMaxspect();
void setLED()
#if debug_flow == 1
  Serial.println();
#endif
void setMoon()
  Serial.println();
#endif
void setVortech()
void setMaxspect()
   reverse_speed = 0;
   forward_speed = 0;
   reverse_speed = 0;
#if 0
#endif
#if debug_flow == 1
  Serial.println();
#endif
Tide tide;
#include <Tide.h>
Happy to help! That's what's great about this community and open source in general... RA ROCKS!
-LeoD
PostPosted: Mon Feb 29, 2016 8:03 pm
I didnt look at your full code yet. But it would be nice to wrap this into a function and have it be used like a standard mode function. Then you could use the anti-sync speed as an output to control the direction.
PostPosted: Mon Feb 29, 2016 9:16 pm
Here, this should do nicely. The only thing I learned from here is that we need to add in the libraries either to let each function decide its speeds under different modes like feeding and waterchange OR we add a FeedingAntiSyncSpeed and WaterChangeAntiSyncSpeed variables. For now I took that part out of the function. You could always implement it manually if you like by not using those variables, or maybe we can just manage it in the libraries too, I'd have to look closer how that works.
The libraries do this:
ReefAngel.cpp:          if (DCPump.FeedingSpeed < 100)
ReefAngel.cpp:                  SyncSpeed=DCPump.FeedingSpeed;
ReefAngel.cpp:                  AntiSyncSpeed=DCPump.FeedingSpeed;
Anyway, here's the function a little more simplified
byte setMaxspect(byte minSpeed, byte maxSpeed, boolean PulseSync)
  int forward_speed=minSpeed;
   // swap between forward and reverse every X seconds
   reverse_speed = ShortPulseMode(0,100,ReefAngel.DCPump.Duration*2,true);
   if (reverse_speed == 100) {
     // while we are going in reverse increase the speed by 10
     forward_speed = ShortPulseMode(minSpeed+10, maxSpeed+10,ReefAngel.DCPump.Duration,true);
     forward_speed = ShortPulseMode(minSpeed,maxSpeed, ReefAngel.DCPump.Duration, true);
  if (PulseSync) {
    return forward_speed;
    return reverse_speed;
PostPosted: Tue Mar 01, 2016 2:20 pm
lnevo wrote:Here, this should do nicely. The only thing I learned from here is that we need to add in the libraries either to let each function decide its speeds under different modes like feeding and waterchange OR we add a FeedingAntiSyncSpeed and WaterChangeAntiSyncSpeed variables. For now I took that part out of the function. You could always implement it manually if you like by not using those variables, or maybe we can just manage it in the libraries too, I'd have to look closer how that works.
I like how you simplified it. This may be a stupid and obvious question, but how do you set the max and min speed for forward and reverse?
  if (PulseSync) {
Return to Ask anything here
