Portal relay times
PostPosted: Thu Mar 17, 2016 4:00 pm
Not a big deal but, I checked the portal to see when my AWC was turning on and noticed that when it ran each time, it ran for 35 min. I have it set to run for 30 minutes, four times a day. Is there a reason why it might be running five minutes longer than it should?
PostPosted: Thu Mar 17, 2016 4:08 pm
The portal only gets date every 5 minutes. I think it could just be because of that. I'll take a look at your code later this weekend
PostPosted: Thu Mar 17, 2016 4:24 pm
Thanks, Lee. After I posted this I thought about how the portal only updates every 5 minutes. I will have to time it when it comes on next time to see if it's running the correct amount of time.
PostPosted: Sun Mar 20, 2016 7:24 am
Yeah, I'm pretty sure you're only running for 30 minutes. The way you've got the code for AWC it really can't be more or less. Let us know what you see when you're in front :)
PostPosted: Sun Mar 20, 2016 11:37 am
Ok will do.
Return to Ask anything here
