I got it working but have a few issues
Posted: Wed Apr 20, 2016 12:34 am
by Echo5delta16
it took a while but got the cable, the wifi box and the code genie working.. problem i have now is that when i generate the code it tells me there is no member by that name. i tried to use a preset code to veirfy that all works so i picked "VortechSetup" and uploaded it. it was a successful up load but the relay box is now clicking. and the control box says "assigning slaves done"
Re: I got it working but have a few issues
Posted: Wed Apr 20, 2016 12:44 am
by Echo5delta16
i went back through the wizard again and uploaded it again and it was successful this time and i see all the screens on the control box but the relay box is still clicking. i have a light plugged in to one outlet and it goes off and on. the clicks are each one of the outlets becoming powered then going back off. is this normal?
Posted: Wed Apr 20, 2016 3:08 am
by cosmith71
That sounds like the test code.
Posted: Wed Apr 20, 2016 4:35 am
by Echo5delta16
That would make sense but any idea why it still did it after I replaced the code with a different code? At least I think I did. It said upload successful.
Posted: Wed Apr 20, 2016 8:34 am
That sounds like the manufacturer test code used to test the board.
Add this line right below ReefAngel.Init();
InternalMemory.write(Mem_B_TestMode,255);
