help with jeabo rw-8 staying on
PostPosted: Wed Jun 15, 2016 4:04 pm
I have two rw-8s one pump that will not turn off anymore since adding the wifi unit. neither when I press water change or feeding does it shut off. that was the only change. also when I unlug from the pwm port it stays running. any help would be appreciated
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.AddWifi(); // Add Wifi
    ReefAngel.FeedingModePorts = Port2Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port8Bit;
    // Define labels for 2014 LCD screen
    //box0
    ReefAngel.CustomLabels[0]="T5HO";
    ReefAngel.CustomLabels[2]="FugeLight";
    ReefAngel.CustomLabels[3]="Heater";
    ReefAngel.CustomLabels[4]="ScrubLight";
    ReefAngel.CustomLabels[5]="Kalk_Mixer";
    ReefAngel.CustomLabels[6]="Kalk_ATO";
    ReefAngel.CustomLabels[7]="RO_ATO";
    //lowers minimum speed for DC pump
    InternalMemory.DCPumpThreshold_write(0);
    //gives random sopmething to randomize against
     randomSeed(now()/SECS_PER_DAY);
  ReefAngel.Portal("slm222"); //wifi
    ReefAngel.MHLights( Port1,12,30,14,30,5 ); //t5ho
    ReefAngel.MHLights( Port2,7,0,22,0,5  );  //skimmer
    ReefAngel.StandardLights( Port3,18,0,10,0 ); //fugelight
    ReefAngel.StandardHeater( Port4,785,788 ); //heater
    ReefAngel.StandardLights( Port5,18,0,10,0 ); //scrubber light
    ReefAngel.DosingPumpRepeat( Port6,0,240,25 ); // kalk mixing every 6 hours for 25 seconds
    ////// Wave Pattern Code Start
    //Hardcode minimum speed of DC pumps
    ReefAngel.DCPump.Threshold=0;
    static int rmode;
    byte modes[] = { ReefCrest, NutrientTransport, TidalSwell, Lagoon, Else, ReefCrest, Else };
    changeMode=false;
    static unsigned long feeding;
    // after feed mode Continue NTM for the 60 minutes
    if (now()-feeding<1800) {
    ReefAngel.DCPump.Mode=Else;
    //7am to 9am - wake up from night mode
    else  if (hour()>=7 && hour()<9){
    ReefAngel.DCPump.Duration=350;
    ReefAngel.DCPump.Mode=Sine;
    ReefAngel.DCPump.Speed=50;
    //9am to 10am - ramp up to random
    else  if (hour()>=9 && hour()<10){
    ReefAngel.DCPump.Mode=Lagoon;
    ReefAngel.DCPump.Speed=60;
    //10am to 6pm - Random
    else if (hour()>=10 && hour()<18) {
    ReefAngel.DCPump.Speed=70;
    //6pm to 7pm - slow down from random
    else  if (hour()>=18 && hour()<19){
    //7pm to 9pm - slow down to night mode
    else  if (hour()>=19 && hour()<21){
    // Night mode
    else  {
    ReefAngel.DCPump.Duration=450;
    ReefAngel.DCPump.Speed=40;
    ////// Wave Pattern Code End
    ////// ATO RO and Kalk Settings
if ((hour()>18 || hour()<9) && (ReefAngel.Params.PH < 822))
    ReefAngel.SingleATO( true,Port7,600,0 );   //  Sump switch. Kalk schedule 6pm - 7am if pH < 8.25  If ATO/Kalk runs for 10 minutes=600 seconds, then shut off.
    ReefAngel.Relay.Off(Port8);
    ReefAngel.SingleATO( true,Port8,500,0 );   //  Sump switch.  If ATO/RoDi runs for 8.20 minutes=480 seconds, then shut off.
    ReefAngel.Relay.Off(Port7);
    ////// End ATO RO and Kalk Settings
PostPosted: Wed Jun 15, 2016 4:27 pm
ok. not sure whats going on for sure. but when the command is issued for water change or feeding what happens is the wavemaker goes to a slow speed vs shutting off. any help would be appreciated
PostPosted: Wed Jun 15, 2016 5:20 pm
upon further inspection the pump may be the internals of the pump may be whats going bad. not sure...
PostPosted: Wed Jan 11, 2017 11:20 pm
did you ever get help with this or figure it out? I haven't had any luck getting any of the RA gurus to respond to my threads???
I don't think it's the pump (gotta be something in the code/libraries). I had the same issue and did a lot of trouble shooting. for me, its just the antisync on highATO that stays on high and doesn't respond to feedings and water change commands. I currently have both my dc pumps working off the lowATO channel flawlessly but id really like to get the antisync working to alternate flow as opposed to having them work in Sync. Hope to hear some possible solutions soon.
Return to Ask anything here
Users browsing this forum: Google [Bot] and 1 guest
