DC return pumps
Posted: Sun Aug 14, 2016 3:11 pm
Does anyone have a list of DC return pumps that can be controlled by the RA? Have the Jebao DCS now, but want one that can be controlled so I can use Roberto's standpipe code.
http://forum.reefangel.com/
#include <Tide.h>
#define Level 80
#define MinPWM 50
#define OperatingPWM 70
long nummillis=5000;
byte PWMValue=0;
boolean override=false;
ReefAngel.DDNS("Damien");
ReefAngel.AddMultiChannelWaterLevelExpansion(); // Multi-Channel Water Level Expanion Module
ReefAngel.FeedingModePorts = Port1Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port5Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit;
InternalMemory.WaterLevelMax_write(1800);
ReefAngel.StandardHeater( Port3,780,785 );
ReefAngel.WaterLevelATO(4,Port4,240,28,31);
ReefAngel.Relay.Set(Port8, (now()%(6*SECS_PER_HOUR))<(30*SECS_PER_MIN));
PWMValue=OperatingPWM;
if (ReefAngel.WaterLevel.GetLevel(2)<Level-4)
override=true;
PWMValue+=4;
if (ReefAngel.WaterLevel.GetLevel(2)>Level+4)
override=true;
PWMValue-=4;
if (millis()-lastmillis>nummillis && override)
override=false;
if (!override) PWMValue=OperatingPWM;
if (ReefAngel.WaterLevel.GetLevel(2)>Level+10) PWMValue=MinPWM;
PWMValue=constrain(PWMValue,MinPWM,100);
ReefAngel.PWM.SetActinic(PWMValue);
if (ReefAngel.WaterLevel.GetLevel(1)<5) //Disable the port until overriden manually
ReefAngel.Relay.Override(Port8,0); //Saltwater Reservoir
if (ReefAngel.WaterLevel.GetLevel(1)>80) // Set port back to auto
ReefAngel.Relay.Override(Port8,2);
if (ReefAngel.WaterLevel.GetLevel(2)>89) //Overflow
ReefAngel.Relay.Off(Port1);
ReefAngel.Relay.On(Port1);
if (ReefAngel.WaterLevel.GetLevel(3)>87) //ATO Reservoir
ReefAngel.Relay.Off(Port5);
if (ReefAngel.WaterLevel.GetLevel(3)<1)
ReefAngel.Relay.On(Port5);
ReefAngel.Portal( "Ismaclst" );
override=true;
PWMValue+=4;
override=true;
PWMValue-=4;
override=false;
override=true;
PWMValue+=2;
if (ReefAngel.WaterLevel.GetLevel(2)>Level+2)
override=true;
PWMValue-=4;
override=false;
ReefAngel.PWM.SetDaylight(0);
static unsigned long levelHigh;
static unsigned long pumpOff;
static boolean pumpBool;
if (ReefAngel.WaterLevel.GetLevel(3) < 50) levelHigh=now();
if (now()-levelHigh > 20*SECS_PER_MINUTE && !pumpBool) {
pumpBool=true;
pumpOff=now();
if (now()-pumpOff() < 5*SECS_PER_MINUTE) {
} else {
pumpBool=false;
#include <Tide.h>
#define Level 79
#define MinPWM 45
#define OperatingPWM 68
byte PWMValue=0;
override=true;
PWMValue+=2;
override=true;
PWMValue-=4;
override=false;
if (now()-levelHigh > 20*SECS_PER_MIN && !pumpBool) {
pumpBool=true;
pumpOff=now();
if (now()-pumpOff() < 5*SECS_PER_MIN) {
} else {
pumpBool=false;
Sketch uses 60,092 bytes (23%) of program storage space. Maximum is 253,952 bytes.
Global variables use 2,978 bytes (36%) of dynamic memory, leaving 5,214 bytes for local variables. Maximum is 8,192 bytes.
#include <Tide.h>
#define Level 76
#define MinPWM 45
byte PWMValue=0;
override=true;
PWMValue+=2;
override=true;
PWMValue-=4;
override=false;
if (ReefAngel.WaterLevel.GetLevel(4) < 50) levelHigh=now();
if (now()-levelHigh > 16*SECS_PER_MIN && !pumpBool) {
pumpBool=true;
pumpOff=now();
if (now()-pumpOff < 15*SECS_PER_MIN) {
} else {
pumpBool=false;
