DC return pumps
PostPosted: Thu Nov 17, 2016 8:45 pm
Hey Lee, Did you ever get a chance to look into this?
PostPosted: Fri Nov 18, 2016 1:52 am
No :( I haven't even been here on the boards. Been so backed up at work with end of year. I do owe you a solution... will try by this weekend. Feel free to harass me on FB too :)
PostPosted: Fri Nov 18, 2016 11:09 am
Thanks! Appreciate you helping me on this.
PostPosted: Mon Nov 21, 2016 5:29 am
Ok, I think this should be good to get started. I've reviewed it a few times in my head. Let me know what you think.
  static unsigned long levelHigh;
  static unsigned long pumpOff;
  static boolean pumpBool;
  if (ReefAngel.WaterLevel.GetLevel(3) < 50) levelHigh=now();
  if (now()-levelHigh > 20*SECS_PER_MINUTE && !pumpBool) {
    pumpBool=true;
    pumpOff=now();
  if (now()-pumpOff() < 5*SECS_PER_MINUTE) {
    ReefAngel.Relay.Off(Port1);
    ReefAngel.Relay.On(Port1);
    pumpBool=false;
PostPosted: Mon Nov 21, 2016 8:31 pm
It appears to be what I was wanting. I will upload this later and let you know for sure.
Thanks Lee!
PostPosted: Tue Nov 22, 2016 1:45 am
I added this to my code but it did not compile. The first error was I had to change MINUTES to MIN. Now I get a few more.
PostPosted: Tue Nov 22, 2016 1:59 am
Here is my code:
#include <Tide.h>
#define Level         79
#define MinPWM        45
#define OperatingPWM  68
long nummillis=5000;
byte PWMValue=0;
unsigned long lastmillis=millis();
boolean override=false;
  ReefAngel.DDNS("Damien");
  ReefAngel.AddMultiChannelWaterLevelExpansion();  // Multi-Channel Water Level Expanion Module
  ReefAngel.FeedingModePorts = Port1Bit | Port6Bit;
  ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
  ReefAngel.LightsOnPorts = Port5Bit;
  ReefAngel.OverheatShutoffPorts = Port3Bit;
  InternalMemory.WaterLevelMax_write(1800);
  ReefAngel.StandardHeater( Port3,780,785 );
  ReefAngel.WaterLevelATO(4,Port4,240,28,31);
  ReefAngel.Relay.Set(Port8, (now()%(6*SECS_PER_HOUR))<(30*SECS_PER_MIN));
  PWMValue=OperatingPWM;
  if (ReefAngel.WaterLevel.GetLevel(2)<Level-4)
    override=true;
    PWMValue+=2;
  if (ReefAngel.WaterLevel.GetLevel(2)>Level+2)
    override=true;
    PWMValue-=4;
  if (millis()-lastmillis>nummillis && override)
    override=false;
  if (!override) PWMValue=OperatingPWM;
  if (ReefAngel.WaterLevel.GetLevel(2)>Level+10) PWMValue=MinPWM;
  PWMValue=constrain(PWMValue,MinPWM,100);
  ReefAngel.PWM.SetActinic(PWMValue);
  if (now()-levelHigh > 20*SECS_PER_MIN && !pumpBool) {
    pumpBool=true;
    pumpOff=now();
  if (now()-pumpOff() < 5*SECS_PER_MIN) {
    pumpBool=false;
  if (ReefAngel.WaterLevel.GetLevel(1)<5) //Disable the port until overriden manually
    ReefAngel.Relay.Override(Port8,0);    //Saltwater Reservoir
  if (ReefAngel.WaterLevel.GetLevel(1)>80)   // Set port back to auto
    ReefAngel.Relay.Override(Port8,2);
  if (ReefAngel.WaterLevel.GetLevel(2)>89) //Overflow
  if (ReefAngel.WaterLevel.GetLevel(3)>87) //ATO Reservoir
    ReefAngel.Relay.Off(Port5);
  if (ReefAngel.WaterLevel.GetLevel(3)<1)
    ReefAngel.Relay.On(Port5);
  ReefAngel.Portal( "Ismaclst" );
PostPosted: Tue Nov 22, 2016 2:50 am
Sorry, change pumpOff() to pumpOff.
Sketch uses 60,092 bytes (23%) of program storage space. Maximum is 253,952 bytes.
Global variables use 2,978 bytes (36%) of dynamic memory, leaving 5,214 bytes for local variables. Maximum is 8,192 bytes.
PostPosted: Wed Nov 23, 2016 2:17 pm
So I finally installed the code you did for me today. I submersed the stand pipe for my sump level so it would activate. It shows that the sump level is at 82 and it was suppose to turn the return off when it was 50 or higher. I waited past the 16 minutes but nothing happened. Not sure what is going on. Here is my latest code.
#include <Tide.h>
#define Level         76
#define MinPWM        45
byte PWMValue=0;
    override=true;
    PWMValue+=2;
    override=true;
    PWMValue-=4;
    override=false;
  if (ReefAngel.WaterLevel.GetLevel(4) < 50) levelHigh=now();
  if (now()-levelHigh > 16*SECS_PER_MIN && !pumpBool) {
    pumpBool=true;
    pumpOff=now();
  if (now()-pumpOff < 15*SECS_PER_MIN) {
    pumpBool=false;
Return to Ask anything here
