dimming leds on ATO high and low ports
Posted: Tue Dec 20, 2016 5:55 pm
by Reefology
Hi, hoping to get some help allocating leds and jebao wave makers to dimming ports.
currently I have my leds controlled via my relay box, they simply come on and off at set times. I also have jebao pumps hooked up to my dimming ports and I love the controlling them via the portal. Now, what I'd like to do is have my leds gradually ramp up to 100 meaning I need to remove the jebaos?! or, I remember reading a post somewhere that stated the ATO ports can control the lights. My questions are:
1. I have 4 channels (2 blue and 2 white), can I wire the blues on ATO low and the whites on ATO high?
2. I'm sure the leds are 0-10v and the ATOs are 0-5v. do I need to make a mod somewhere to wire these?
3. Or, should I just wire the lights to the dimming ports and mod the jebao cables and put them on the ATO ports?
what is easiest to do and makes the most sense. any input would be great.
thanks
Re: dimming leds on ATO high and low ports
Posted: Tue Dec 20, 2016 6:08 pm
Get the dimming expansion module
Posted: Tue Dec 20, 2016 7:06 pm
by Reefology
thanks Roberto
. does that mean the ato's won't work for the lights? I know they'll work for the jebaos. don't I have to remove a resistor from the current jebao cable to work on the ato?
Posted: Tue Dec 20, 2016 7:09 pm
Yes, you would need to mod the jebao cable to control them with the ATO port.
But you asked for the easiest
Posted: Tue Dec 20, 2016 9:23 pm
by Reefology
fair enough...that will be my next upgrade. Can you point me to a thread that shows/describe the mod?
Posted: Wed Dec 21, 2016 9:20 pm
by Reefology
got my lights working on 0-10v dimming channels but my wp40 isn't working. I removed R2 resistor from the jebao cable to make it a 5v signal going in.
can someone please look at my code to see if its causing the problem
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit;
pinMode(lowATOPin,OUTPUT);
pinMode(highATOPin,OUTPUT);
//ReefAngel.Relay.On( Port5 );
ReefAngel.DayLights( Port2 );
ReefAngel.StandardLights( Port4, 19,0,7,0);//Protein skimmer, Reactor 7pm-7am
ReefAngel.StandardLights( Port5 );
ReefAngel.DosingPumpRepeat1( Port6 );
ReefAngel.DosingPumpRepeat2( Port7 );
ReefAngel.DosingPumpRepeat3( Port8 );
ReefAngel.DCPump.LowATOChannel = Sync ; // WP40
//ReefAngel.DCPump.HighATOChannel = AntiSync ; // other DC pump
// DC pumps
// To run this code must choose Custom in portal
static int rmode;
byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
if (now()%1800==0 || changeMode==true) { // Change every 30 mins (1800seconds) or controller reboot
rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
changeMode=false;
static unsigned long feeding;
// Continue NutrientTranspot Mode for 30 minutes after feeding
if (now()-feeding<1800) {
// Night mode (go to 30%)
} else if (now()%SECS_PER_DAY<39600 || now()%SECS_PER_DAY>=82800) { // 11am / 11pm
ReefAngel.DCPump.Mode=Gyre;
ReefAngel.DCPump.Speed=30;
} else {
Posted: Thu Dec 22, 2016 11:13 am
by Reefology
seems to be a problem with highATO port running my pump full and not shutting off on feedings like the lowATO does?
thanks
