Chinese Led Dimming
PostPosted: Sat Mar 04, 2017 11:57 am
by Express Reef
Can this also work on the PWM module?
https://youtu.be/0SsT28rSmjI
Re: Chinese Led Dimming
PostPosted: Sun Mar 05, 2017 3:40 am
by cosmith71
If the ballast is 0-10v analog then you will need 0-10v dimming. PWM wouldn't work.
PostPosted: Sat Mar 18, 2017 7:03 am
by Express Reef
cosmith71 wrote:If the ballast is 0-10v analog then you will need 0-10v dimming. PWM wouldn't work.
Is the RA no able to do analog dimming? How can I check if my RA is analog or PWM? I know I got the PWM expansion.
PostPosted: Sat Mar 18, 2017 1:38 pm
by cosmith71
Look on the bottom of your relay box. I believe on the analog versions there is a sticker of some kind denoting this. PWM boxes have no sticker.
Newer dimming expansion modules are switchable between analog and PWM, 5 and 10v for each of the 6 outputs.
PostPosted: Sun Mar 19, 2017 11:16 am
by Express Reef
How will I be able to check if my PWM module is cable of doing analog?
PostPosted: Sun Mar 19, 2017 12:49 pm
by cosmith71
Take off the cover. The newer one has jumpers to select 5 or 10v and analog or PWM for each channel.
