NEW RA* will not take initial setup
PostPosted: Wed Mar 07, 2018 5:18 pm
Nothing.
Simply plug RA* to the ethernet port on your router.
PostPosted: Wed Mar 07, 2018 7:56 pm
Would this work?
https://www.amazon.com/GL-iNet-GL-MT300 ... merReviews
PostPosted: Wed Mar 07, 2018 8:37 pm
Do you need a wireless setup?
If you don't, you just need to connect to your internet router directly.
If you do want to go wireless, this module should work as long as it can act as a wireless client. I can't remember if they do. I'll send you the ones I have tested in the past.
PostPosted: Thu Mar 08, 2018 12:39 am
please do
PostPosted: Thu Mar 08, 2018 8:36 am
https://www.bhphotovideo.com/c/product/ ... HUQAvD_BwE
PostPosted: Thu Mar 08, 2018 11:24 am
On my unit I have to hold reset button down until after compile then release it....It will then load after playing with the reset button. I have two RA+ and they both do that.
Hope that will help
PostPosted: Fri Mar 09, 2018 8:44 am
Thanks for the info! I ordered and will let you know how it works!
PostPosted: Sat Mar 10, 2018 9:56 am
OK, got the client router and it works BUT I can't find the documentation on how I get my connected Reef Angel Star to take code remotely or stream my settings.
Is there another manual I'm not seeing? What is the process?
D
PostPosted: Sat Mar 10, 2018 10:00 am
Were you able to load your code at least once using the cable through the webwizard?
PostPosted: Sat Mar 10, 2018 3:31 pm
Yes via a PC
Return to Ask anything here
