Reef Angel Wifi Adress
Posted: Mon Jun 10, 2019 12:11 pm
by Christo
Hi Guys
How do I change my Reef Angel wifi address in the Portal
Re: Reef Angel Wifi Adress
Posted: Mon Jun 10, 2019 5:17 pm
It does it automatically as soon as your RA connects to the server
Posted: Thu Jun 13, 2019 2:55 am
by Christo
Okay. Thanks. But Still struggling
Posted: Thu Jun 13, 2019 3:00 am
by Christo
When setting up my Wifi attachment, The Wifi wizard goes thru everything
Everything is true getting IP adress ect. but the bottom line reads....
Trying to connect to your router..........
Posted: Thu Jun 13, 2019 8:32 am
Posted: Fri Jun 14, 2019 2:29 am
by Christo
Thanks! Will givecit a go....
Just one think... I says trying to connect to router
But I have a slow flashing green LED. That means its
Connected Right? But is trying to connect to router.
Strange
Posted: Wed Jun 19, 2019 9:49 am
by Christo
Okay.... I installed teraterm, downloaded the zip file, made changes as nessasary,
Changed baud rate to 57600, and ran the macro.
Macro ran Fine... Everything read “AOK” But now my WiFi attachment has a blinking
Blue and Green Light.
What to do Now?
Posted: Wed Jun 19, 2019 9:56 am
Did you change the ssid and password?
It is case sensitive.
Posted: Wed Jun 19, 2019 7:26 pm
by Christo
rimai wrote:Did you change the ssid and password?
Yes. SSID and Passphrase changed
Posted: Wed Jun 19, 2019 8:40 pm
Do you happen to have a space?
If so, you need to use $ instead of space.
Posted: Thu Jun 20, 2019 3:55 am
by Christo
rimai wrote:Do you happen to have a space?
I have an underscore "_" in my SSID
Posted: Thu Jun 20, 2019 3:58 am
by Christo
This is what I get.
P.S. Passphrase edited
x=0
while x<>121
messagebox 'Start WiFly module configuration' 'Webscan Config Program'
;this macro all sent with 5 msec character delay
timeout=10
send '$$$'
wait 'CMD'
sendln 'factory RESET'
wait 'Set Factory Defaults'
sendln 'reboot'
wait '*READY*'
; Begin user settings
send '$$$'
wait 'CMD'
sendln 'set ftp address 198.175.253.161'
wait'AOK'
sendln 'save'
wait 'config'
sendln 'set wlan ssid GlidePath_Wifi'
wait 'AOK'
sendln 'set wlan pass **********'
wait 'AOK'
sendln 'set option deviceid ReefAngelWifi'
wait 'AOK'
sendln 'set w j 1'
wait 'AOK'
sendln 'set c c 0'
wait 'AOK'
sendln 'set c r 0'
wait 'AOK'
sendln 'set c o 0'
wait 'AOK'
sendln 'set i d 1'
wait 'AOK'
sendln 'set c i 3'
wait 'AOK'
sendln 'set dns name
www.reefangel.com'
wait 'AOK'
sendln 'set i h 104.36.18.155'
wait 'AOK'
sendln 'set i r 80'
wait 'AOK'
sendln 'set i f 0x06'
wait 'AOK'
sendln 'set s t 0x10'
wait 'AOK'
sendln 'set u m 2'
wait 'AOK'
sendln 'set i p 2'
wait 'AOK'
sendln 'set u b 57600'
wait 'AOK'
sendln 'set s p 0'
wait 'AOK'
sendln 'set c s 1420'
wait 'AOK'
sendln 'save'
wait 'config'
sendln 'save user'
wait 'user'
sendln'reboot'
;inputbox 'Configure another module (y/n)' 'WiFly Config Program'
; convert inputstr to ASCII int value
; str2code x inputstr
endwhile
Posted: Thu Jun 20, 2019 9:40 am
This is the macro file. Are you sure you ran it?
Did you get the messageboxes at the start and end?
Posted: Thu Jun 20, 2019 7:57 pm
by Christo
rimai wrote:This is the macro file. Are you sure you ran it?
Yes. Got the message boxes at the beginning and then again
at the end.
If I run the macro, The Wifi attachment then has a green and blue light blinking.
If I run the Wifi utility, I have a Slow blinking Green light with message “ Trying to
Posted: Thu Jun 20, 2019 10:07 pm
Trying to connect to router is normal.
It just means that it wasn't able to setup upnp on your router.
Not sure why you get blue when running the macro.
If you enter the correct ssid and passphrase, it should connect.
Can you pull the "get e" log after you run the wifi utility?
Posted: Wed Jul 24, 2019 1:42 am
by Christo
Okay... So after a bit of a cool down period I tried again.
Using Wifi utility: After selecting serial port and clicking Connect I get this message:
**ERROR- Please disconnect and reconnect the Reef Angel Wifi Attachment from the USB-TTL cable and try again.
Then Using the macro:
At first I ran 9600 baud rate and got a hole lot of "hieroglyphics" on the screen.
Then I tried 57600 and got this message:
HTTP/1.1 400 Bad Request
Content-Type: text/html; charset=us-ascii
Server: Microsoft-HTTPAPI/2.0
Date: Wed, 24 Jul 2019 07:59:19 GMT
Connection: close
Content-Length: 326
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""
http://www.w3.org/TR/html4/strict.dtd">
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request - Invalid Verb</h2>
<hr><p>HTTP Error 400. The request verb is invalid.</p>
</BODY></HTML>
Now Currently Nothing is connecting to the Wifi Attachment.
Posted: Wed Jul 24, 2019 9:17 am
You didn't run the macro correctly.
It must be at 57600 before you run it.
