Reef Angel Star Controller
PostPosted: Sat Nov 11, 2017 1:09 pm
Ok.
And the RANet and Relay work fine with it too?
PostPosted: Sat Nov 11, 2017 1:17 pm
RANet works fine, but the main relay box will need one of the old relay modules, since RA* only has expansion ports.
PostPosted: Sat Nov 11, 2017 1:24 pm
rimai wrote:RANet works fine, but the main relay box will need one of the old relay modules, since RA* only has expansion ports.
The $50 ones that you don't have in stock yet?
That you are talking about here...
rimai wrote:In order to use your main relay box as expansion, you need one of the old relay expansion modules, which we are in the process of getting them built to sell in the web store.
They cost $50.
We only have one of them in stock before we get the next batch.
PostPosted: Sat Nov 11, 2017 1:54 pm
Yes, those ones. I have a few on hand
PostPosted: Sat Nov 11, 2017 3:08 pm
Ok.
I have to get the money together.
PostPosted: Mon Nov 13, 2017 10:35 am
Me too lol
Sent from my iPhone using Tapatalk Pro
Believe it or not.... I can ask even stupider questions than this one.
PostPosted: Tue Nov 14, 2017 4:19 pm
rimai wrote:If you use the webwizard, simply add this to setup():
ReefAngel.AddExtraTempProbes();
Cool, does it just use the extra inputs?
PostPosted: Tue Nov 14, 2017 7:11 pm
No, you have to splice more probes in parallel to the existing ones or create your harness that has more connectors or get something like this from amazon or any other electronic store.
They are y-split cables for computer fans.
y split.jpg (12.41 KiB) Viewed 282 times
https://www.amazon.com/dp/B01DRE2UAI/re ... 0599452956
PostPosted: Mon Nov 27, 2017 8:24 pm
How far away can the expansion relay sockets be from the head unit?
Here is what I would like to do...
600gal display needs a relay box and vortech control(already have) ~35 ft from controller.
Sump room needs...
2 to 3 relay boxes
11 temp probes
Orp (already have)
Sg (already have)
PHx2
I already have an expansion module. Do I need anything else to make this work?
Would like to flush a large touch screen pc or tablet into the wall to use for continuous portal display. How customizable is the portal these days?
I was going to go with a plc to control all my lights and use my existing RA+ for monitoring but like the idea of a hardwire so am considering making the jump.
What issues do you see?
PostPosted: Mon Nov 27, 2017 8:51 pm
I think your best bet is to use the RANet.
It's an RF wireless option that allows you to control the relay expansion box without the USB connection.
Simply power it and it will pick up signal from the head unit.
viewtopic.php?f=3&t=4763
PreviousNext
Return to Standard
