Unexpected end of stream
PostPosted: Mon Jun 24, 2019 5:54 pm
Ok well at least you know that it's working now. So the app is working properly now?
Did you re-setup the port forwarding? It sounded like you went from .2 to .8 or vice-versa. The port-forwarding needs to match that.
Apologies for any miscommunication.
PostPosted: Thu Jul 11, 2019 8:03 am
Here is the current state. When home on wifi, connecting works (sometimes takes a few attempts of getting errors), but when the app is set to away and I'm off home network it will not connect and says timeout. However....the portal updates all parameters but shows connection status of unreachable address.....thoughts on this? Appreciate the help as always! @rimai @lnevo
PostPosted: Thu Jul 11, 2019 9:42 am
Sounds like port forwarding
PostPosted: Thu Jul 11, 2019 5:25 pm
I agree 100%
PostPosted: Fri Jul 12, 2019 9:33 am
So it's possible that port forwarding is half set up? Forwarding on home network but not off network? How is the portal updating partially via external networks?
PostPosted: Fri Jul 12, 2019 4:37 pm
There is no forwarding in the "Home" network. Forwarding is to get you from your router to the RA inside your network. The portal gets updated because the RA makes an *outgoing* connection to the portal every 5 minutes, but you cannot connect internally to a device (RA) behind your firewall/router which is where the forwarding comes into play. On the router you want to make sure the port 2000 is forwarded to the IP address of your RA on port 2000 and make sure the port is open on the outside. (sometimes you have to add this also to the firewall)
Previous
Return to Standard
