Ok I removed the ' in the SSID and ran the Macro fix in Tera Term; but the lights are blinking blue. Here is the code Marco that was config to my Wifi:
CMD
factory RESET
Set Factory Defaults
<4.41> reboot
*Reboot*CMD
set ftp address 198.175.253.161
AOK
<4.41> save
Storing in config
<4.41> set wlan ssid Moes Tavern
AOK
<4.41> set wlan pass ____Hiden__
AOK
<4.41> set option deviceid ReefAngelWifi
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
<4.41> set dns name www.reefangel.com
AOK
<4.41> set i h 198.171.134.6
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
<4.41> set u b 57600
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*
Any thoughts? Should I run Wifi utility? I thought you run the macro, you don't need to use the wifi utility anymore. It should be already configured.
Troy
Wifi issue - all LED blinking
HodagReef
Re: Wifi issue - all LED blinking
So I did the config with the wifi utility tool and the lights is just blinking green. Here is the code:
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM4
> set u b 57600
> set s p 0
> save
> reboot
Removing connection to COM4
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM4
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 79680 3 WiFly_GSX-2.36
< 22 1052 10 config
< 23 1052 10 user
< 24 88548 3 wifly-GSX-441-r1057
< 25 88548 3 wifly-GSX-441-r1057
< 34 83648 3 WiFly_GSX-2.45
< 79 46632 3 wps_app-GSX-131
< 80 66240 3 eap_app-GSX-101
< 81 74920 3 web_app-GSX-106
< 82 37282 0 web_config.html
< 83 512 0 link.html
< 103 Free, Boot=24, Backup=25
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Moes$Tavern
< set w s Moes$Tavern
< AOK
< <4.41>
> set w p ____hiden___
< set w p _____hiden__
< AOK
< <4.41>
< set w k 00000000000000000000000000
< AOK
< <4.41>
< set ftp address 198.175.253.161
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=Moes Tavern
< Chan=11
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=OK,renew=64796
< Boot=2045
< Time=FAIL
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< IP=192.168.1.162:2000
< NM=255.255.255.0
< GW=192.168.1.1
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Found router WRT1900ACS
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 22 1052 10 config
< 23 1052 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Moes$Tavern
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=Moes Tavern
< Chan=11
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< Boot=2045
< Time=FAIL
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.1.1
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Blinking green is good. It means it is connected to your wifi.
