troubleshooting suggestions
trentdingo
Post by trentdingo »
Hey all, my RA quit working today... I am trying to determine the reason now. It was working perfectly fine yesterday.
The head unit does not light up and I cannot hear the relays powering on/switching when plugged in anymore. I pulled apart the unit and checked the fuse, does not seem to be blown and bypassing it did nothing.
So what else should i try to determine the issue here?
Thanks in advance for any help, Trent
Re: troubleshooting suggestions
Pretty sure it is the power supply.
Which generation is the relay box?
trentdingo
I believe it is the second generation box? it says RA Relay Box 5.0 in th ecorner
I cannot post links, however a picture can be found here:
http://i304.photobucket .com/albums/nn185/trentdingo/photo-84.jpg
You got PM
