no pwm driver
PostPosted: Fri Aug 05, 2011 12:44 pm
with regards to dimming led's, what if your driver doesnt take a pwm signal, it only takes 1-10 volts.
will you still be able to dim it using reef angel?
thanks
PostPosted: Fri Aug 05, 2011 12:50 pm
You other post was moved and was answered already.
viewtopic.php?f=2&t=195
PostPosted: Fri Aug 05, 2011 1:53 pm
o.k. sorry,
this LED driver thing is confusing to me.
i havent build it yet, i'll use the driver which is easiest for the reef angel to control.
so just doing my research.
and when i talked to reefledlights, they said they dont recommend using pwm dimming since it changes the light spectrum.
instead i was advised to get a different controller. lol. driver is easier to replace at $30.
Return to Standard
