Page 1 of 2
Re: LCD screen hardware change
Posted: Mon May 06, 2013 6:12 pm
by cosmith71
By the time I figured it out, you'd have the formal version up. :mrgreen:
--C
Posted: Tue May 07, 2013 12:13 am
by JHP
is there a charge for the upgrade?
Posted: Tue May 07, 2013 7:51 am
No, as long as you have a gen 2 screen.
Posted: Wed May 08, 2013 2:12 pm
by Sacohen
I received my new LCD screen today.
From the looks of the announcements at the top of each forum library 1.0.4 is the latest, but I followed the link to the change log at the bottom of that thread and it show 1.0.5.
Is this correct or is 1.0.6 out yet?
Posted: Wed May 08, 2013 3:30 pm
It will be released tonight.
Posted: Wed May 08, 2013 6:00 pm
by Sacohen
Great. I hope to have time to work on setting this up this weekend.
Posted: Thu May 09, 2013 8:37 am
by cosmith71
Got the new screen up and running. It is leaps and bounds better looking than my old one.
The response time seems a little slower, though.
Posted: Thu May 09, 2013 8:40 am
That's the trade off, but I think it's worth it, don't you?
Posted: Thu May 09, 2013 8:42 am
by cosmith71
Yes, it's not that bad. It's very smooth and looks gorgeous compared to the gen 2.
--C
Posted: Fri May 10, 2013 9:19 am
by Elevatorguy1
Replaced mine this morning. Very nice looking!
Posted: Mon May 20, 2013 6:01 am
by JHP
Hi
Is this GEN 1 OR GEN 2
/Jan
Posted: Mon May 20, 2013 7:57 am
Gen1.
You are good :)
Posted: Mon May 20, 2013 11:20 pm
by dapg8gt
Going to be replacing mine tomorrow it seems pretty straight forward right? Just pop out the old one and insert the new one?.. Insert code and ready to rock?.. I've gotten used to no screen lol I'm excited? Guessing the screen just pops out?
Posted: Tue May 21, 2013 7:12 am
by cosmith71
Yep, just pull and stick in the new one.
Posted: Tue May 21, 2013 4:00 pm
by dapg8gt
Cool thanks.. should have brought it to work with me lol..
Posted: Fri May 24, 2013 12:55 pm
by Sacohen
Yeah it was easy. It just came out and the new one went in it's place. Just make sure the pins are lined up and it doesn't need any force. If you feel that it is hard, stop, pull it off and check everything is straight and aligned.
Mine came up fine with out having to replace the code.
Posted: Fri Oct 11, 2013 6:24 pm
by OceanWolf
Hi Roberto,
I think I have a Gen2. What should I do?
Onur
Posted: Fri Oct 11, 2013 6:47 pm
Yeap.
PM me for RMA.
Posted: Fri Nov 22, 2013 12:41 am
by Jbowen590
What months were the gen2 sold in?
Posted: Mon Nov 25, 2013 5:49 pm
by kwolfskill
Hi Roberto,
I've had my Reef Angel for a number of months now, and haven't even hooked it up yet because the tank just finally got water in it to cycle it (it has been a slow process getting to this point). Just saw this thread and opened my Reef Angel up, and looks like I have a Gen 2 screen. At the moment I can't PM you, so what should I do?
Kevin
Posted: Mon Nov 25, 2013 9:38 pm
I upgraded your account. Try now.
Posted: Sat Jun 07, 2014 7:27 pm
by JDW
Please excuse my noobish inexperience, but i recently purchased an upgrade board for my RA. I am having the same issues where my screen is acting screwy. It works fine with the old RA board, but when i hook it up to the RA+ it has a single horizontal line that scrolls vertically. I found this post and it mentions that I need to insert a particular code.
"InternalMemory.LCDID_write(255);"
I am not certain where that should go in my RA Wizard program. Below is the code I am using.
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <ReefAngel.h>
////// Place global variable code below here
////// Place global variable code above here
    ReefAngel.FeedingModePorts = Port1Bit;
    InternalMemory.OverheatTemp_write( 790 );
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardHeater( Port3,760,770 );
    ReefAngel.SingleATO( true,Port7,60,0 );
    ReefAngel.Portal( "JDW" );
Posted: Sat Jun 07, 2014 8:10 pm
Place it right above ReefAngel.Init();
Posted: Sat Jun 07, 2014 8:24 pm
by JDW
Thank you Roberto, fixed it right up
Posted: Fri Jul 31, 2015 11:22 pm
by Xender
Hi Roberto !
Thanks a lot !
It works but I had to delete one line also :
Posted: Mon Nov 09, 2015 7:59 am
by Matthewgype
thanks for giving me the necessary information
Posted: Sat Jul 23, 2022 3:21 pm
by JclaasSA
Hi
The screen on my standard Reef Angel unit fades/distorts after a while.
I fitted my Reef Angel Plus screen to it and then the backlight comes on, but displays nothing (even after entering the code "InternalMemory.LCDID_write(255);").
I also tried to upload all the different screen generation codes to the standard Reef Angel without any luck.
The fading/distorting screen displays something on the Reef Angel Plus without changing it's code.
The reason I want the standard Reef Angel sorted out is because the Reef Angel Plus pcb is corroded by the joystick which has since stopped scrolling up/down and I am not sure if removing the joystick from the standard Reef Angel and fitting it to the pcb of the Reef Angel Plus would help.
Can someone please advise?
Posted: Sun Jul 24, 2022 12:51 pm
It seems the screen has some issues too. You may need to replace it.
