Page 2 of 2
Re: LCD screen hardware change
Posted: Mon Nov 25, 2013 9:38 pm
I upgraded your account. Try now.
Posted: Sat Jun 07, 2014 7:27 pm
by JDW
Please excuse my noobish inexperience, but i recently purchased an upgrade board for my RA. I am having the same issues where my screen is acting screwy. It works fine with the old RA board, but when i hook it up to the RA+ it has a single horizontal line that scrolls vertically. I found this post and it mentions that I need to insert a particular code.
"InternalMemory.LCDID_write(255);"
I am not certain where that should go in my RA Wizard program. Below is the code I am using.
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <ReefAngel.h>
////// Place global variable code below here
////// Place global variable code above here
    ReefAngel.FeedingModePorts = Port1Bit;
    InternalMemory.OverheatTemp_write( 790 );
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardHeater( Port3,760,770 );
    ReefAngel.SingleATO( true,Port7,60,0 );
    ReefAngel.Portal( "JDW" );
Posted: Sat Jun 07, 2014 8:10 pm
Place it right above ReefAngel.Init();
Posted: Sat Jun 07, 2014 8:24 pm
by JDW
Thank you Roberto, fixed it right up
Posted: Fri Jul 31, 2015 11:22 pm
by Xender
Hi Roberto !
Thanks a lot !
It works but I had to delete one line also :
Posted: Mon Nov 09, 2015 7:59 am
by Matthewgype
thanks for giving me the necessary information
Posted: Sat Jul 23, 2022 3:21 pm
by JclaasSA
Hi
The screen on my standard Reef Angel unit fades/distorts after a while.
I fitted my Reef Angel Plus screen to it and then the backlight comes on, but displays nothing (even after entering the code "InternalMemory.LCDID_write(255);").
I also tried to upload all the different screen generation codes to the standard Reef Angel without any luck.
The fading/distorting screen displays something on the Reef Angel Plus without changing it's code.
The reason I want the standard Reef Angel sorted out is because the Reef Angel Plus pcb is corroded by the joystick which has since stopped scrolling up/down and I am not sure if removing the joystick from the standard Reef Angel and fitting it to the pcb of the Reef Angel Plus would help.
Can someone please advise?
Posted: Sun Jul 24, 2022 12:51 pm
It seems the screen has some issues too. You may need to replace it.
