ATO Problem
Rey
ATO Problem
Post by Rey »
I need help with my ATO. I plugged it into the port and and when I enabled ATO from RA Client, it doesn't do anything. Here is my code.
Settings in RA Client is 60s Timeouts and 1h Interval.
// Autogenerated file by RAGen (v1.0.4.92), (09/09/2011 09:18)
// RA_090911_0918.pde
 #define DisplayImages
 #define WavemakerSetup
 #define DateTimeSetup
 #define VersionMenu
 #define ATOSetup
 #define MetalHalideSetup
 #define DirectTempSensor
 #define DisplayLEDPWM
 #define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
  ReefAngel.FeedingModePorts = B00001100;
  ReefAngel.WaterChangePorts = B00001100;
  ReefAngel.OverheatShutoffPorts = B00011111;
  ReefAngel.LightsOnPorts = B00000011;
  ReefAngel.Relay.On(Port8);
  // Random value from 60seconds to whatever is stored in internal memory
  ReefAngel.Timer[1].SetInterval(random(5, InternalMemory.WM1Timer_read()));
  ReefAngel.Timer[1].Start();
  ReefAngel.Relay.On(Port3);
  // Specific functions
  ReefAngel.MHLights(Port1);
    ReefAngel.Relay.Toggle(Port3);
    ReefAngel.Relay.Toggle(Port4);
  ReefAngel.StandardHeater(Port5);
  ReefAngel.StandardFan(Port6);
  ReefAngel.StandardATO(Port7);
Rey
Re: ATO Problem
Post by Rey »
Anyone?
Re: ATO Problem
Did you read this thread?
http://forum.reefangel.com/viewtopic.php?f=7&t=240
StandardATO uses both float switches.
Rey
Re: ATO Problem
Post by Rey »
Yes, i've read that. How do I know if my setup is SingleATO or DualATO? I can't use the RA Gen because I keep getting "not enough space/memory" error.
Re: ATO Problem
You are using none of them.
You are using StandardATO, which needs both switches. One pointing up and the other down.
Rey
Re: ATO Problem
Post by Rey »
Thanks Roberto. I will try it out.
Rey
Re: ATO Problem
Post by Rey »
it still doesn't work. i have both ATO valve plugged in, follow the instruction from the link you provided, still no success.
