Yes, the entire wifi protocol is serial based.
You can just use it
Send "GET /r99" and you get back an XML data containing all the parameters and relay statuses.
You can also code it to have the controller send out data periodically.
The ReefAngel.WebBanner() sends out data for the web banners and you could just read and use.
So, it's up to you to decide either push or pull.
