Black Screen (off)
ufgators2k
Black Screen (off)
Post by ufgators2k »
Anyone else have any issues with the screen staying off with the new libraries? I powered the device on/off twice and reloaded the code to no avail.
// Needs to be global for DrawCustomGraph()
int ScreenID=1;
// Custom Menu setup
#include <avr/pgmspace.h>
prog_char menu2_label[] PROGMEM = "Refugium Light On/Off";
prog_char menu3_label[] PROGMEM = "Skimmer On/Off";
prog_char menu5_label[] PROGMEM = "ATO Clear";
menu4_label, menu5_label
// Define Relay Ports by Name
// Port 1 - ATO
// Port 2 - Fuge Light
// Port 3 - Actinic Light
// Port 4 - Daylight
// Port 5 - Power Head
// Port 6 - Return Pump
// Port 7 - Heater
// Port 8 - Skimmer
#define Ato                1
#define Refugium           2
#define BlueLEDs           3
#define WhiteLEDs          4
#define PowerHead          5
#define ReturnPump         6
#define Heater             7
#define Skimmer            8
    //ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize Menu
    // Ports toggled in Water Change Mode - turn off ATO/Power Head/Return Pump/Skimmer
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8;
    // Ports toggled when Lights On / Off menu entry selected - Actinic/Daylight
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.Relay.On( Port5 ); // Power head
    ReefAngel.Relay.On( Port6 ); // Return Pump
    ReefAngel.Relay.On( Port8 ); // Skimmer
    ReefAngel.PHMin=576;
    ReefAngel.PHMax=839;
    ReefAngel.StandardLights( Port2,20,15,10,30 );
    ReefAngel.StandardLights( Port3,9,30,21,30 );
    ReefAngel.StandardLights( Port4,10,0,20,45 );
    ReefAngel.StandardHeater( Port7,755,770 );
    ReefAngel.PWM.SetDaylight( PWMParabola(12,30,18,30,0,40,0) );
    ReefAngel.PWM.SetActinic( PWMParabola(10,00,20,30,0,65,0) );
    // Use one float sensor (ATOLow) for the return section and one
    // for the ATO reservoir (ATOHigh)
    ReefAngel.SingleATO(true,Port1,45,0);
      ReefAngel.Relay.Off(Port1);
    ReefAngel.Portal("ufgators2k");
// Custom Main Menu
// Menu Code
void MenuEntry1() {
void MenuEntry2() {
  // Toggle refugium light between on/auto.
  ReefAngel.Relay.Override(Refugium, ReefAngel.Relay.Status(Refugium)+1);
void MenuEntry3() {
  // Toggle skimmer on/off.
  ReefAngel.Relay.Toggle(Skimmer);
void MenuEntry4() {
  ReefAngel.OverheatClear();
void MenuEntry5() {
  ReefAngel.ATOClear();
// Custom Main Screen
void DrawCustomMain() {
  //const int NumScreens=2;
  //static boolean drawGraph=true;
  // Main Header
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 28, 2,"Kopman's Reef");
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
  // Param Header
  DrawParams(5,14);
  //switch (ScreenID) {
  //  case 0:
  //    if (drawGraph) { ReefAngel.LCD.DrawGraph(5,40); drawGraph=false; }
  //    break;
  //  case 1: { DrawStatus(5,40); break; }
  DrawStatus(5,40);
  ReefAngel.LCD.DrawDate(4,122);
  // Draw Relays
  DrawRelays(12,94);
  /*(if (ReefAngel.Joystick.IsLeft()) {
    ScreenID--; drawGraph=true;
  if (ReefAngel.Joystick.IsRight()) {
    ScreenID++; drawGraph=true;
void DrawCustomGraph() {
//  if (ScreenID==0)
//    ReefAngel.LCD.DrawGraph(5, 40);
  char buf[16];
  // Temp and PH
  y+=2;
  y+=6;
  y+=5;
  int t=x;
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,30,y,"ATO Status");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y+10,"Resv",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y+10,"Sump",Font8x16);
  if (ReefAngel.HighATO.IsActive()) { // ATO reservoir is empty
    ReefAngel.LCD.FillCircle(55,y+15,5,COLOR_RED);
    ReefAngel.LCD.FillCircle(55,y+15,5,COLOR_GREEN);
  if (ReefAngel.LowATO.IsActive()) { // Return pump water level is low
    ReefAngel.LCD.FillCircle(70,y+15,5,COLOR_RED);
    ReefAngel.LCD.FillCircle(70,y+15,5,COLOR_GREEN);
  y+=25;
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,15,y,"Heater Status");
  if (ReefAngel.Relay.Status(Heater) == 1) {
    ReefAngel.LCD.FillCircle(105,y+2,5,COLOR_GREEN);
    ReefAngel.LCD.FillCircle(105,y+2,5,COLOR_RED);
  // Display Water level
  //ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"AT0 Level:"); x+=65;
  //ReefAngel.LCD.DrawSingleMonitor(ReefAngel.WaterLevel.GetLevel(),DPColor,x,y,1);
  //x+=5*(intlength(ReefAngel.WaterLevel.GetLevel())+1);
  //ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x, y, "%");
  //y+=12; x=t;
void DrawRelays(int x, int y) {
  // Draw Relays
