Porting from AVR to ARM
Re: Porting from AVR to ARM
Yes I meant SD cards... I would actually challenge you on this. Here are my thoughts With the SD card if something goes wrong with the data storage, I can just replace. I could also use a computer program to change the values(Ascii format)... I could store strings, localize the strings for various languages/cultures, define complex schemes of configuration settings (Think custom screen layouts) - just to name a few ideas... As for the complexity of reading and writing an ascii file, it is a one time hit. For customers that are not developers that rather not compile code, this could be a very easy way to configure settings without having to re-compile.
Just my 2 cents
Just my 2 cents
Roberto et al.
I just got my Reef Angel, although been following its dev for years, but was delayed in getting a tank setup. Now that the tank is getting going, I could justify finally getting an RA. I really am impressed with everything Roberto and the team have put together. Back in the late 90s I hacked my Neptune systems controller and put it on the internet which freaked them out a bit. Its great to see how far along controllers have come.
I am considering building a new head unit built around the the spark core. (I don't have permission to link to sites for some reason but it is w w w . s p a r k . i o
I was in on their kickstarter and should receive mine next month. It has a lot of cool features including integrated wifi and wireless, cloud-based programming etc.. It is based on the Arm M3, so I was wondering about porting issues when I found this thread. I assume the class collisions will still be an issue as its an Arduino one, not a ARM issue. Is that correct?
I don't know how far down the road RA is on developing a new head unit or the architecture, but I'd like to respectively propose that the RA dev team take a look at the Spark Core. If you think it is interesting, I'd be interested in helping out.
Thanks! BTW, got your PM, but I don't have privileges to respond!
Guess, I need to post some more. Hard when you don't want to add to convos just to get your post count up...
Hoping to have some cycles in the next few months to start to dig into all the code and hardware and get a better understanding "under the hood."
As I said, super impressed with what is going on and really appreciate all the hard work Roberto and the community has put into RA.
I already looked into the spark chip, but they were not released and I didn't fund the kickstarter project.
I was waiting for them to come out of pre-order to dig further.
From the specs on their page, do you see anything major that would not work for what is here today or what you are planning in the future? (Specs below)
Spark Core
8 digital I/O pins, 8 analog I/O pins
4 PWM pins; UART (Serial), SPI, I2C, and JTAG peripherals available
Programmed wirelessly (through Spark Cloud), via USB or JTAG
3.3V DC supply voltage (on board power regulator); can be powered by USB Micro
100mA typical current consumption; 300mA peak consumption (during transmit events)
2MB of external flash; EEPROM supplied by CC3000
Microcontroller
STM32F103 microcontroller
ARM Cortex M3 architecture
32-bit 72Mhz processor
128KB of Flash, 20KB of RAM
Wi-Fi module
Texas Instruments SimpleLink CC3000
802.11b/g
Range of 100-300 feet
Spark Core
Microcontroller
Wi-Fi module
802.11b/g
Spark just emailed. They are pushing back delivery again. ugh. Now its Nov 4th
Do you have access to their cloud software to upload codes yet?
Hi,
What's about the new Intel Galileo Platform. Here are some of the specs:
Intel® Galileo includes native Ethernet, SD, USB Host support, USB Client support, RS-232 serial port, and 10 pin JTAG ports. It also includes Arduino* shield connectors compliant with the Arduino* Uno R3 connector definition. Finally it includes a native mini-PCIe connector for the addition of Wi-Fi (for example).
Arduino* Uno R3 is the compatibility. Some shields may not work properly due to hard-coded registers in the shield drivers; however, Intel is working with Arduino and shield owners to correct the drivers.
Intel® Galileo can be connected to the internet by connecting the on-board Ethernet RJ45 connector to your home router. Intel Galileo firmware includes DHCP for automatic configuration of the Ethernet interface with an IP address. It can also be connected wirelessly or over 3G via expansion on PCIe or shields.
Intel® Galileo comes with an integrated onboard NIC and the embedded Linux* on the board has the drivers for the NIC already.
Intel® Galileo does have I/O features often found on desktop boards or laptops and not easily found on an Arduino* boards such as full USB host and PCI express capability.
Can I run Linux on Intel® Galileo?
Yes. Intel® Galileo runs Linux* out of the box. It comes in two flavors; the default is a small Linux. If you add an SD card to your kit, you can add a more fully-featured Linux. Refer to the Intel® Galileo Getting Started Guide and Intel® Quark SoC X1000 IoT Development Kit Software GSG.
Best regards,
Manuel
Best regards,
Manuel
I've been checking out their forum:https://community.sparkdevices.com/
and there are posts by people who have them. The I2C pins are exposed so I believe that would enable plug-in-play for Reef Angel accessories.
They are porting the standard Arduino libraries, but 3rd party libs would need to get ported (like OneWire)
I received a prototype board this week and was able to get the Android ADK working on it so far.
I still need to see if the internal RTC works. All the other features are pretty standard and should be no problem for using them.
The biggest thing was to be able to talk to Android directly, which I was able to get it working.
Oh my, i'm gonna have to keep an eye on this one. Using the ARM means faster and smoother operation. I was looking into the Galileo on adafruit for $99 and using the PCA9685 break out I have from them already and using either a 3.5" or 5" touch-screen.
Hello Roberto,
I too am very excited about an ARM based head unit; and have been considering Spark Core, and also reaserching Udoo.
Udoo seems interesting with both ARM i.MX6 CPU and ARM SAM3X8E Atmel, and according to website "ADK 2012 enabled - UDOO can act simultaneously as an Android host device and its connected ADK."
I'm sure a lot of us are wondering if you could estimate any timescale you might have in mind for a ARM based head unit with Android?
Regards,
Carlos
The features list seems amazing: HDMI and LVDS + Touch, USB OTG, camera connection. This is the direction I would love ReefAngel to go too; I can imagine an awesome aquarium controller already, especially with all the experience from ReefAngel community.rimai wrote:The main goal here is to be able to support the protocol standard USB OTG (On the Go).
You mentioned your progress with the Spark Core, have you also looked at the Udoo?rimai wrote:I received a prototype board this week and was able to get the Android ADK working on it so far.
Regards,
Carlos
Any News on the porting? No new post since 4 months
Hi Roberto,
Any news on a port to a different MCU?
I started it, but never went forward with it.
There were some issues with libraries in too early stages of being used yet, so I decided to wait out a bit.
