Relay outlet port
Rey
Relay outlet port
Post by Rey »
My port 8 is set to always on. How do i set it up so that it's ON 16 hours a day? Below is my code.
// Autogenerated file by RAGen (v1.0.4.92), (09/09/2011 09:18)
// RA_090911_0918.pde
 #define DisplayImages
 #define WavemakerSetup
 #define DateTimeSetup
 #define VersionMenu
 #define ATOSetup
 #define MetalHalideSetup
 #define DirectTempSensor
 #define DisplayLEDPWM
 #define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
  ReefAngel.FeedingModePorts = B00001100;
  ReefAngel.WaterChangePorts = B00001100;
  ReefAngel.OverheatShutoffPorts = B00011111;
  ReefAngel.LightsOnPorts = B00000011;
  ReefAngel.Relay.On(Port8);
  // Random value from 60seconds to whatever is stored in internal memory
  ReefAngel.Timer[1].SetInterval(random(5, InternalMemory.WM1Timer_read()));
  ReefAngel.Timer[1].Start();
  ReefAngel.Relay.On(Port3);
  // Specific functions
  ReefAngel.MHLights(Port1);
    ReefAngel.Relay.Toggle(Port3);
    ReefAngel.Relay.Toggle(Port4);
  ReefAngel.StandardHeater(Port5);
  ReefAngel.StandardFan(Port6);
  ReefAngel.StandardATO(Port7);
Re: Relay outlet port
From what time to what time?
Rey
Post by Rey »
on from 7am to 11pm
  ReefAngel.StandardLights(Port8,7,0,23,0);
Just because it says Lights, doesn't mean it has to be used only for lights :)
Would that work for you?
Rey
Post by Rey »
so even if i already have standardlights in my code this will not conflict with each other?
Nope :)
You can have all 8 ports using StandardLights() function
Rey
Post by Rey »
awesome. Thanks roberto..
Rey wrote:so even if i already have standardlights in my code this will not conflict with each other?
Just make sure you use the long version of the StandardLights function. There are 2 versions of it:
  • Short Version - StandardLights(Port) that uses the internal memory values for the on & off times
  • Long Version - StandardLights(Port, on hour, on minute, off hour, off minute) that uses the values passed in
The short version actually calls the long version using the default internal memory locations for the Standard Lights. Probably more information than what you wanted, but I figured I would clarify things a little more.
