Stray voltage
chapboogie
Re: Stray voltage
Post by chapboogie »
Watching this.....
Sent from my SCH-I535 using Tapatalk
chapboogie
Re: Stray voltage
What was the solution on this?
chapboogie
Re: Stray voltage
Was there a solution?
kevingehrke
Re: Stray voltage
Post by kevingehrke »
I have this problem too. So I took the ph probe and put it into a different cup of water, and stuck in my pinky and got mildly shocked confirming the probe is the leak.
ReEfnWrX
Re: Stray voltage
Post by ReEfnWrX »
Have you guys tried using a grounding probe to ground your aquarium?
I would guess that should prevent the leaking current from affecting your sensors...??
I have found that I almost always get current leak from pumps over time... I've been using grounding probes for the last 2 years because of it
Re: Stray voltage
I added a grounding probe it did nothing for the .2 offset I see in my pH in the tank vs out of the tank.
Would stray voltage reduce the life expectancy of a probe? Mine is no longer holding the calibration. Its my 2nd probe now on a 1.5 yo tank.
Have a lab grade probe on order.
ReEfnWrX
Re: Stray voltage
Post by ReEfnWrX »
Out of curiosity, are you using a pH expansion?
From what Roberto told me, only the pH expansion has galvanic isolation. And from what I have read that should prevent stray voltage from affecting the readings.
Re: Stray voltage
No the primary probe.
ReEfnWrX
Re: Stray voltage
Post by ReEfnWrX »
You may want to look into galvanic isolation and see if you think it will help, if so get the pH expansion... It is on my list to buy soon... Everyone I know with an Apex does not get any voltage interference with their pH probes because the Apex comes standard with Galvanic isolation.
saf1
Re: Stray voltage
Post by saf1 »
ReEfnWrX wrote:You may want to look into galvanic isolation and see if you think it will help, if so get the pH expansion... It is on my list to buy soon... Everyone I know with an Apex does not get any voltage interference with their pH probes because the Apex comes standard with Galvanic isolation.
Not sure I understand this so wanted to ask a question. I have the standard Reef Angel Plus (extra memory I guess, right?) and it the pH unit built in. Ironically reading the boards today I came across this and while I've not measured for stray voltage (I'll check tonight) I am seeing random spikes in my pH reading on the ReefAngel Client (v3.0). I'll see a pretty regular graph and then all of a sudden it will dive down to 6 or so then right back up to 8 or whatever it is at.
So in this case and having the pH on the controller itself how do you or do you need to run with Galvanic isolation? Or am I mixing something up here altogether (which is probably the case).
Re: Stray voltage
The dips in the client is related to the client I think.
ReEfnWrX
Re: Stray voltage
Post by ReEfnWrX »
saf1 wrote:Not sure I understand this so wanted to ask a question. I have the standard Reef Angel Plus (extra memory I guess, right?) and it the pH unit built in. Ironically reading the boards today I came across this and while I've not measured for stray voltage (I'll check tonight) I am seeing random spikes in my pH reading on the ReefAngel Client (v3.0). I'll see a pretty regular graph and then all of a sudden it will dive down to 6 or so then right back up to 8 or whatever it is at.
Roberto can correct me if I am wrong. But if I understood him correctly, there is Galvanic isolation in the pH expansion unit but not in the base pH port on the RA unit.
It would be interesting if someone with a pH expansion unit who thinks they may have or used to have stray voltage would test their pH in the tank and in a cup of water with the base pH port and do the same test using their pH Expansion port.
I do plan to buy a pH expansion very soon as galvanic isolation is supposed to prevent the affects of stray voltage on Probes readings.
Re: Stray voltage
Keep in mind that the stray voltage is not coming from the probe.
It's originated in one of your equipment that is plugged into RA. Usually powerheads, heaters, pumps, LED drivers or even a PC computer.
The probe is just providing a point of differential voltage and completing the circuit.
If you have any other point of differential voltage dipped into the water, you would still get the stray voltage, regardless of the probe being in the water or not.
So, you are only treating the symptom by isolating the probe. You are not treating the cause.
It's the same analogy when you dump chemicals or shut the lights off to kill algae in your tank. You are simply treating the symptom.
The best is to identify which equipment is the problematic one and remove/replace it.
ReEfnWrX
Re: Stray voltage
Post by ReEfnWrX »
This is true and I agree, however... Majority of times when stray voltage is a factor it is coming from a main pump which typically cost a decent amount of money.. Every return pump I've had has caused stray voltage after a couple of months and I do not think it is worth it to replace a $100+ pump every couple months.
From my research, the only time stray voltage is to be of concern is in two situations.
1. You use probes that do not have galvanic isolation and therefor the reading will be affected slightly.
2. If your tank is not grounded every time you touch the tank and feel the current or a shock... You are not the only one feeling it, everything that is living in your tank feels it as well, because you are completing the circuit and allowing the current to leave the tank water.... Which is why it is very important to at least get a grounding probe so you are not affecting your livestock every time you touch the tank water.
bmhair03
Re: Stray voltage
Post by bmhair03 »
Roberto what is the meanwell connection if any?. My ph reading drops 2 points when my lights come on. Going to recal but still think it's linked to lights.
Re: Stray voltage
You are not the first one to complain about this and their drivers.
Did you replace any drivers recently or still original drivers?
bmhair03
Re: Stray voltage
Post by bmhair03 »
I believe I switched one out. Others orig. Don't remember which one. :)
Re: Stray voltage
I think they changed something along the way.
Do you know which one is the new one?
The new dimming modules have optical isolation to avoid this problem.
bmhair03
Re: Stray voltage
Post by bmhair03 »
Yes I figured it out. But what would be the fix if any.
Re: Stray voltage
Optical isolation, which the new dimming modules have.
chapboogie
Re: Stray voltage
I have the new dimming module, and it fixed mine.
bmhair03
Re: Stray voltage
Post by bmhair03 »
I think I'll try the old driver. I think I replaced it but it was a matter of too many led shorted out
In the end. Thanks for the heads up. If not then I'll order one. Thanks
RootsRockReefer
Re: Stray voltage
Post by RootsRockReefer »
rimai wrote:Are you using meanwell drivers?
What do you believe meanwell drivers induce to the ra ph probe readings?
Re: Stray voltage
Old meanwell drivers didn't do that.
Somewhere along the line, they changed something that started introducing stray voltage into RA through the dimming signal wire.
RootsRockReefer
Re: Stray voltage
rimai wrote:Old meanwell drivers didn't do that.
I will unplug my LED set up and pull the dimming lead tomorrow and see if the PH probe acts normal. Its reading is absolutely unpredictable on a newly set-up controller.
I have bulk lab grade ph7 & ph10 solution. No matter how long I leave the probe in the solution the reading drifts upward?
Is the only way to avoid the galv isolation problem to get the PH expansion module? This should be mentioned in the description I feel misled, why should I buy a ph expansion when we are already sold a PH port?
chapboogie
Re: Stray voltage
The dimming expansion will solve the problem. It isolates the dimming lead from the ph.
RootsRockReefer
Re: Stray voltage
So if I simply removing the dimming leads from my LED drivers to the main unit, the PH probe should operate normally then, correct? This would completely remove the only dimming circuit I am using.
chapboogie
Re: Stray voltage
Probably, but that will also make your lights not work.
RootsRockReefer
Re: Stray voltage
So its official in my case, within a minute after pulling the dimming leads off the Relay Box the PH reading went from its 2.45 to the more expected 7.98. Re-calibrated the probe for kicks came in at 8.21 which is right in line with my standard PH test kits reading. After an hour the reading was still basically steady reading like 8.17 to 8.22. Pushed the dimming leads back on the relay box the PH reading within a matter of moments was back down to the 2.54 level.
Dimming module is the key i suppose,
paulvisco
Re: Stray voltage
Post by paulvisco »
I was running into to same issue last night with the low PH reading (6.00) in the test solutions it was 7.00 and 10.00 put some tank water in a cup and that was 8.00 but probe in the tank and it went down..
Turned out to be a ATO float switch was causing the leak and the bad readings. with Roberto's help last night we had it fixed in about 10 minutes..
Thanks all for the quick turnaround on problem solving...
