Relay #3 is stuck in the ON position.
I rebooted the board and unplugged/plugged the system. LCD screen shows relay as if it was off. However, anything that plugs into it, powers on. I have it as a doser powering an Toms aqua lifter pump.
It only turns on for one minute a day. Yesterday, it started on time and it never stopped...
Any ideas or suggestions are welcome.
Re: Relay #3 is stuck in the ON position.
Is the port still on if you unplug the svga and leave just the relay box powered on?
Yes, when svga is unplugged, the relay remains ON as do the pwm dimmers...
That seems like the relay went bad somehow.
You will need to send back for repair.
PM for details.
PM for details.
Hi I am having the same issue. Where can I have my relay box repaired in South Africa?
You can replace it yourself if you are good with soldering or send it back to us.
