Gyre Mode??
Gyre Mode??
Hi All - I searched but I cannot find what 'Gyre Mode' does.
Can anyone explain?
Can anyone explain?
Re: Gyre Mode??
A gyre is like when you create a whirlpool in a swimming pool. At some point the momentum builds up and it has a strength of its own. The idea is one run pump in constant for x amount then switch the gyre into another direction.
Re: Gyre Mode??
Nice! I love new things!lnevo wrote:A gyre is like when you create a whirlpool in a swimming pool. At some point the momentum builds up and it has a strength of its own. The idea is one run pump in constant for x amount then switch the gyre into another direction.
how would I code Gyre? What do the numbers mean Example:ReefAngel.PWM.SetDaylight( GyreMode (10,20,true));
Just curious - Do you have a mode preference? I have a 60 cube with 2 x wp-25s - what would you recommend?
Re: Gyre Mode??
I responded to you other post with some code that includes Gyre. You need a duration, a minimum, and a maximum. With two pumps (sync and anti-sync) one is off while the other is running.
I use gyre at night and else during the day.
Re: Gyre Mode??
cosmith71 wrote:I responded to you other post with some code that includes Gyre. You need a duration, a minimum, and a maximum. With two pumps (sync and anti-sync) one is off while the other is running.
Awesome! Thank you very much!
Re: Gyre Mode??
Gyre is just like Long Pulse but with round edges. So it ramps up and back down while the opposing pump is off and then switches. The "duration" argument is in minutes, btw, not seconds, to support longer than 4 minutes. Since "Duration" is a byte number if it was in seconds it would overflow at 255 seconds.
Re: Gyre Mode??
Good info - do you think this is a good mode for a reef tank ?AlanM wrote:Gyre is just like Long Pulse but with round edges. So it ramps up and back down while the opposing pump is off and then switches. The "duration" argument is in minutes, btw, not seconds, to support longer than 4 minutes. Since "Duration" is a byte number if it was in seconds it would overflow at 255 seconds.
- Rodasphoto
- Contact:
Re: Gyre Mode??
Great read! Thanks for posting the article.lnevo wrote:http://www.advancedaquarist.com/2007/1/aafeature
Re: Gyre Mode??
if (hour()>=8 && hour()<12)
ReefAngel.PWM.SetDaylight( TidalSwellMode(60,true) );
ReefAngel.PWM.SetActinic( TidalSwellMode(60,false) );
else if (hour()>=12 && hour()<16)
ReefAngel.PWM.SetDaylight(millis()%1250>800?60:0);
ReefAngel.PWM.SetActinic(millis()%1250<800?0:60);
else if (hour()>=16 && hour()<19)
ReefAngel.PWM.SetDaylight( LongPulseMode(30,60,20,true) );
ReefAngel.PWM.SetActinic( LongPulseMode(30,60,20,false) );
else if (hour()>=19 && hour()<23)
ReefAngel.PWM.SetDaylight( ElseMode(60,10,true ));
ReefAngel.PWM.SetActinic( ElseMode(60,10,false ));
ReefAngel.PWM.SetDaylight(SineMode(30,40,30,true) );
ReefAngel.PWM.SetActinic(SineMode(30,40,30,false) );
This is what I have in my code in RA+ How do I add GyreMode to replace SineMode in my code .I want to have a slow GyreMode at night. Maybe from 30% to 50% speed.
Thanks.
Re: Gyre Mode??
Change SineMode to GyreMode and the arguments will be speed / duration (in minutes / true or false
Re: Gyre Mode??
This is great info. Thanks! I'm planning to add jebao controls to mine and was wondering how it works
Justin (San Francisco),
sent from tapatalk
sent from tapatalk
Re: Gyre Mode??
Lee, which is correct?lnevo wrote:Change SineMode to GyreMode and the arguments will be speed / duration (in minutes / true or false
ReefAngel.PWM.SetDaylight( GyreMode(40,70,10,true)); //Ramp from 40% to 70% with 10 min duration in sync mode
ReefAngel.PWM.SetActinic( GyreMode(40,70,10,false)); //Ramp from 40%to 70% with 10 min duration in Antisync mode
Or
ReefAngel.PWM.SetDaylight( GyreMode(70,10,true)); //Ramp up to 70% in 10mins in sync mode
ReefAngel.PWM.SetActinic( GyreMode(70,10,false)); //Ramp up to 70% in 10 mins in Antisync mode
Thanks.
Dr Davaraj
Re: Gyre Mode??
Thanks Lee.lnevo wrote:The second one
Dr Davaraj
Re: Gyre Mode??
The globals.h file say we need to specify a min % a max...?
'byte GyreMode(byte, byte, int, boolean)'
Re: Gyre Mode??
I think you are right. My second code gave errors, but the first code gave no errors and is working.Smotz wrote:The globals.h file say we need to specify a min % a max...?
Dr Davaraj
