I recently upgraded my old RA with RA+ motherboard ... but on the new MB the old LCD not work ...
Any idea?
This is my code:
boolean ATOerror=false;
/********* configurazione di porte **************
port1: luce alba/tramonto (4000k / 3000k)
port2: luce notturna (led blu)
port3: Luce diurna (6000K - plafoniera)
port4: Pompe acqua (filtro e circuito co2 / raffreddamento)
port5: Elettrovalvola CO2
port6: Sistema di raffreddamento (condizionatore + ventole)
port7: Riscaldatore
port8: Pompa rabbocco automatico
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port3Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port5Bit;
InternalMemory.OverheatTemp_write( 300 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port7,245,255 );
ReefAngel.StandardFan( Port6,260,275 );
// luci diurne
if (hour()<12) { //
ReefAngel.StandardLights( Port1,7,30,12,0 ); // lampada singola
ReefAngel.StandardLights( Port3,8,0,11,30 ); // plafoniera
} else {
ReefAngel.StandardLights( Port1,20,0,22,00 ); // lampada singola
ReefAngel.StandardLights( Port3,16,0,21,00 ); // plafoniera
// luce notturna - Moonlights
if ( hour() >= 21 && hour () <= 24 ) {
ReefAngel.StandardLights( Port2,20,50,23,59 );
} else if ( hour() >= 4 && hour () <= 8 ) {
ReefAngel.StandardLights( Port2,5,00,8,00 );
} else {
ReefAngel.Relay.Off( Port2 );
// ReefAngel.PHControl( Port5,690,822 );
if (ReefAngel.Params. PH >= 725 ) {
ReefAngel.Relay.On(Port5); // If sensor PH <= HighPH - turn on the CO2
} else if (ReefAngel.Params. PH <= 680) {
ReefAngel.Relay.Off(Port5); // If sensor PH <= HighPH - turn off the CO2
} else {
ReefAngel.StandardLights( Port5,7,0,20,00 ); // If sensor is beetween HighPH and LowPH - turn on the CO2 from 7:00 to 20:00
// LowATO = Tanica vuota, spengo la pompa se no si rovina
// HighATO = Troppo pieno fermo la pompa prima di fare disastri
if(!ReefAngel.LowATO.IsActive() || !ReefAngel.HighATO.IsActive()) {
ReefAngel.LowATO.StopTopping();
ReefAngel.HighATO.StopTopping();
ReefAngel.Relay.Off(Port8);
//ReefAngel.LED.On();
ATOerror = true;
} else {
ReefAngel.WaterLevelATO(Port8,300,88,95); // 120 seconds timeout, turn on at 88% and turn off at 95%}
ATOerror = false;
ReefAngel.AddWifi();
